Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 11-18-2005, 03:53 PM
zerophatman zerophatman is offline
Question Steering seems.. loose
Hey, i have a 97 jimmy and when i drive down the road the steering just dosnt seem right.. there is alot of play in the wheel. sometimes you need to actually turn the wheel a little bit to just go straight if the road is on a bit of an angle. its not an alignment problem. just wondering if anyone else has this problem and what some options are to fix it. Thanks
Old 11-18-2005, 07:08 PM
dwausa dwausa is offline
Send a message via AIM to dwausa Send a message via MSN to dwausa
Re: Steering seems.. loose
i have alot of play in my steering wheel as well. i have a 96 jimmy. bout 1inch of play before the car starts turning.
if i remember correctly GM said that 1inch of play is within specs.
Old 11-18-2005, 09:03 PM
I think mines more than an inch. My mom has a 2002 blazer and that has a little play. probably an inch, but mines alot worse.
Old 11-19-2005, 05:44 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
2 main things contribute to steering slop in our trucks... The steering box, and the intermediate shaft. Replace your steering box with a zq8 steering box (quicker ratio) and replace your intermediate shaft with either a new steering shaft or a solid shaft replacement. What happenes is that the rag joint at the base of the intermediate shaft wears out. The rag joint is not a seperately serviceable item.
Look at this thread http://www.automotiveforums.com/vbul...+steering+slop
