Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-18-2005, 02:19 PM
yuraRS yuraRS is offline
Question b18 antifreeze leak from block? water pump?
hey, im owner of a 92integra ls and i found a leak of antifreeze from the block on the side where the pulleys located(driver side) from the lover or mid section.... did anyone had this problem before or anyone who know what it may be ? I NEED HELP, thank you ..... is it water pump? if it is, than how to replace it?
Old 11-18-2005, 06:45 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
It could be a waterpump. I haven't owned a b18, but if they have a coolant pipe, that can also leak (not common though).
To remove the waterpump, you need to take off the timing belt, so take off the valve cover, remove the upper timing belt cover, and the lower one, then release the tension on the belt, remove the belt, replace the pump, and belt, reinstall the belt and make sure to tension corectly. It would be alot easier if you had even a cheap manual, besides, they have pictures which help alot.
Old 11-18-2005, 06:53 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: b18 antifreeze leak from block?
http://www.c-speedracing.com/howto/timingbelt/tbelt.php
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-18-2005, 07:49 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
sounds like water pump. is your car overheating ?
Team Lonely Drivers
