Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-18-2005, 12:15 PM
Dsmith678 Dsmith678 is offline
Ram 1500 brakes
3 months ago I had new brake shoes put on my truck...2 months later I started hearing a grinding noise at times that would stop if I slightly tapped the brake. It has now gotten worse and sometimes feels as if the front brakes are being pressed when in fact they are not...I had it in the dealership last week for an unrelated check engine light so they checked it out and stated that my pads were almost gone.
What would have caused this? ...Did they not get installed correctly and have been rubbing ever since I had them installed.? also note I have no ABS lights on or anything.. If they were installed incorrectly I certainly don't want to take back to same place to get fixed..
Car Carpet Man
Old 11-18-2005, 12:20 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Ram 1500 brakes
How old is the truck? It's possible that your calipers are sticking, that they used inferior pads, or that they installed them incorrectly. I'd take a look at them, and definitely avoid going to the same place again.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 11-18-2005, 04:20 PM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
Re: Ram 1500 brakes
Check your rear drums, the could be caked with brake dust causing the front brakes to be doing all the work. Had it happen on my 99. The front was doing about 90% of the braking because brake dust was built up in the rear.
Pictures of the Truck
Old 11-21-2005, 01:20 PM
Re: Re: Ram 1500 brakes
Thanks for the tips...It is a 1998 4wd 1500....Point above could be the issue..cause they didn't even look at the drums when I had them changed..all they did was change the front pads...Im gonna take to another shop this week and have them look at it...
another note my check engine light issue was a speed sensor for the transmission..had tran serviced at the same time they changed the sensor..
Car Carpet Man
