Old 11-18-2005, 08:59 AM
86parky 86parky is offline
running rough only in low idle
86 PA runs fine in high idle. When drops back down to low idle car shakes mainly when mph are around 45/55 . It seems to happen also when not under load. Car only has 35k have changed about every part in it. Thanks for your time.
Old 11-18-2005, 09:14 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: running rough only in low idle
to get started, I'd check the engine and transaxle mounts. Also a quick check of the balancer, especially if it's been removed.
Old 11-18-2005, 07:21 PM
Re: Re: running rough only in low idle
[quote=wrightz28]to get started, I'd check the engine and transaxle mounts. Also a quick check of the balancer, especially if it's been removed.[/QUOT
Thank's for the quick reply. I did have the blancer replaced about 6 months ago. The one that was on the car was differnt from the one that was stock. I was told GM updated the part. It seemed to be running like that befor it was changed. I will check into the engine snd trans mounts Sat. Thanks
Old 11-20-2005, 11:18 PM
mikelund mikelund is offline
rough idle can also be caused by old vacuum line/connectors. Have you replaced or checked vacuum lines? Or even to see if one is off a connection.
Old 11-23-2005, 05:04 AM
Had taken car to a couple of shops. They told me they checked air lines, electrical system, and couldn't pull any codes. There for they couldn't find any problems, but knew car wasn't right. I'm thinking of taking it to the dealer. I just hope there is someone who know's the older 3.8.
