Throttle Body Vacuum Hoses
As you face the throttle body on my 91 3cyl, you have 3 small neoprene hoses connected at the base. What is the correct path for the hose coming from the front left? My hood sticker or manual isn't clear. Thanks in advance.
Dave |
Re: Throttle Body Vacuum Hoses
Well if I understand you correctly, that left hose curves under a metal bracket that has a solenoid valve (EGR vacuum control), that hose then curves around the solenoid and connects to the top of it. Blake |
Re: Re: Throttle Body Vacuum Hoses
Thanks for the reply Blake and anyone else. My system is similar to the one pictured in this link http://www.prokee.hu/suzukat/siwft1/64.htm . All of this seems to be intact on my car except for the throttle body connection. I presently have the EGR system attached to the center orifice on the front base of the throttle body but I'm not sure this is right. Thanks,
Dave |
Re: Re: Re: Throttle Body Vacuum Hoses
Anyways.. the left one is correct and the center is typically capped off. |
