Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 11-18-2005, 01:01 AM
dabramow dabramow is offline
99 Passat GLX steering problems
Hi, as I was driving y'day, my battery light went on and then it became nearly impossible to steer. Any ideas what is causing this? I checked my power steering fluid and it is full. No clue as to what else to check?
Thanks in advance
Old 11-20-2005, 09:28 PM
captain_video captain_video is offline
Re: 99 Passat GLX steering problems
How's your serpentine belt look? If the battery light came on then it sounds like the alternator isn't charging which means that the power steering pump also isn't working if your belt is either broken or losing tension and slipping. Check the belt tension if the belt looks OK.
Old 11-22-2005, 10:14 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: Re: 99 Passat GLX steering problems
cha ching..... $$$$
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
