Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 11-17-2005, 10:19 PM
quicksand quicksand is offline
transmission
i have a 1990 toyota camry 4 cylinder 2wd it has 118,000 miles i was thinking about flushing the trans well not the whole thing just what would come out when a dropped the pan. it hasn't been flushed since probaly it had 60-70,000 miles. I was jus wondering if i should do it becasue i know sometimes cleaning it. if its bad just makes it worse. Any comments would be appreciated
Old 11-18-2005, 11:37 AM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
No, it's a big misconception. Cleaning is good. Flush it then drain the pan with every oil change. You'll never have a problem with it.
You can also pickup some 3/8" fuel/oil hose, some hose clamps & find a sued (but good & clean) oil / transmission cooler. Install that after the stock one & you can rest assured of a long transmission life.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
Old 11-18-2005, 12:44 PM
gator2764 gator2764 is offline
You can always drain the pan, refill and drive around for a few minutes and repeat this for about 5 or more times. It will not get all of the fluid changed but you will get most. I think I did my 95 about 10 times one saturday when I had some free time to kill. I have 195K on it now and it still runs fine.
