Go Back   Automotive Forums Car Chat > Toyota > Sienna
Old 11-17-2005, 09:03 PM
cityboy cityboy is offline
1998 sienna keyless remote programming code
Does anyone have the programming code for a 1998 Sienna XLE. Both my remotes have stopped working. Could it be a different problem? The dealer wants $100 to diagose problem.
Old 11-17-2005, 11:28 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: 1998 sienna keyless remote programming code
What type of remotes do you have? The factory ones (GQ43VT7T) or the Dealer/Port installed ones (BAB237131-022) ?
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 11-18-2005, 04:08 PM
Re: Re: 1998 sienna keyless remote programming code
I have the factory ones GQ43VT7T.
Old 11-25-2005, 06:51 PM
Onblsht's Avatar
Authorized Vendor
The factory one uses these:
http://xastir.tamu.edu/el009t98.pdf
Old 11-28-2005, 09:54 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Moved to Sienna Forum
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 06-12-2006, 07:31 AM
josepheh josepheh is offline
Question Re: 1998 sienna keyless remote programming code
This thread is my best lead so far... Tip of the cap for providing the reference to for the factory-installed remote. I happen to be looking for the programming codes for the 98 Sienna, but for the Dealer/Port remote (BAB237131-022). Any advice?
Old 02-12-2007, 08:18 PM
ToyoRich ToyoRich is offline
I tried clicking that pdf link but it doesn't connect. Any others you know of? I'm trying to program a factory remote for my 98 sienna.
Thanks
Old 02-20-2007, 04:18 PM
Onblsht's Avatar
Authorized Vendor
1. Locate the ECU commonly located below the driver's seat. It's a grey box about 4" by 4" by 1.5". It has a little green button on the side which is the reset button.
2. Turn key to 'ON' position.
3. Press green reset button on ECU for 3 seconds.
4. Within 5 seconds after releasing reset button on ECU, press and release the button on your remote you want programmed. System should 'chirp' if programmed correctly.
5. Turn key to 'LOCK' position and programming is finished.
To disable the passive arming (so it doesn't set alarm automatically):
1. Turn key to 'ON'.
2. Press and hold both remote buttons for 2+ seconds.
3. Press and release the top remote button twice.
4. Turn key to 'LOCK'.
