Old 11-17-2005, 10:00 PM
frizbal frizbal is offline
Send a message via MSN to frizbal Send a message via Yahoo to frizbal
best type of suspension
Ok, i have a 96 3.8 bird. I figured i need new shocks because when i hit too hard of a bump or dip in the road i bottom out. I drive 5 miles of dirt road to school everyday then back and was wondering what kind of shock would give me the most for a comfortable ride with still enough support to keep from bottoming out. Or if i have to pick and choose i would go with comfort anything would help....thanks
Old 11-17-2005, 10:04 PM
Re: best type of suspension
I was hoping to keep it relatively cheap if possible. but if not still post anyway thanks.........sean
Old 11-18-2005, 12:00 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
KYB and QA1 are pretty good for non adjustable and adjustable but I also suggest tighening things up with a strut tower brace and subframes. That way you can get rid of the pesky roll as well.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 11-18-2005, 11:11 AM
tuske427 tuske427 is offline
Send a message via AIM to tuske427
I'd suggest you purchase stiffer springs. The springs are your "suspension" and they are what will keep you from bottoming out.
the shocks job is to keep the springs from bouncing up and down (like a pogo stick) this is why when you see cars with worn shocks, they're constantly bouncing up and down as they drive along.
you mentioned you have a v-6 car. If you step up to WS-6 springs, this would probably be plenty adequate. you don't have the weight of a v-8 in the front so you probably won't need much more than this.
Of course, a good set of shocks, and other support braces can compliment the supension for a great overall package.
As for cost- you can pick up a set of ws-6 springs used for a decent price. check on ebay or at an f-body salvage yard like Billy graham salvage (not the evangelist!).
Good luck!
Long live the muscle car
Old 11-20-2005, 04:58 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
putting on WS6 springs might be bad because they're so tight. you'll get a really rough ride, but you wont bottom out. if you change the shocks, you'll bottom out less because it slows the springs compression rate..by a little...? (Correct me if im wrong on that assumption).
