Old 11-17-2005, 08:28 PM
dallisb dallisb is offline
Cruise control
Hi all, I have just bought a used alero and by the sounds of things this may have been a bad purchase.
I too am having problems already. My cruise control will not engage. The light on the steering wheel lights up but the light on the dash does not. All the fuses that I have checked that are related to cruise are working. Can anyone give me suggestions on where to look for problems or what may need to be replaced? This is rather frustrating because when I did the test drive it worked perfectly. I tried the holding the button down method but that doesn't work.
Thanks
Dallis
Old 11-25-2005, 04:40 PM
alero99 alero99 is offline
Send a message via ICQ to alero99 Send a message via AIM to alero99 Send a message via Yahoo to alero99
i have had the same problem a couple of times too...mine only works when it feels like it-its only happened twice but the first i turned the car on and it wouldnt work so i just ignored it because it worked the next time i drove it. the next time it happened i turned the car off and turned it back on and it worked...haha i dunno whats up with it
Old 11-25-2005, 05:44 PM
lostidealist lostidealist is offline
Unhappy My Cruise Control has never worked..
I've checked all the relevant fuses for the cruise control and they're all fine.
I get a similar problem with just the light coming on when I hit cruise, but if I try to set it, I get a whOLe lotta nothin'. I don't care too much because I rarely like to use it (kind of a control thing), but for longer trips with minimal traffic, it'd be nice to have.
Anyone figured out what might be the cause or how to fix it?
Btw, mine is a 2000 Alero, and the steering wheel with controls is original (at least to my knowledge).
Old 11-27-2005, 09:34 AM
vamc's Avatar
vamc vamc is offline
Re: Cruise control
Bad connection, rust?
Old 11-27-2005, 05:13 PM
mkt624 mkt624 is offline
I have a '01 alero & my cruise messed up similar to yours but it was still under warranty & they said it was the cruise control module under the hood. I got a receipt & it showed to be $250 for the module, but that was about 2-3yrs ago. Don't know if this will help but thought I would let you know.
