how can i remove a broken valve cover bolt?
i was changing my valve cover gasket and at the end with the last bolt i over torked it and now its broken what can i do to fix this also are there any was to do this with out taking the head off thanks
Re: how can i remove a broken valve cover bolt?
boar it out
can i do it with out taking the heads off?
welll your in a cavalier forum, and aparently you have a cavalier or a ford so this can go either way some times you can sometimes you cant
i got a 96 2.2 cavalier i just replaced the head gasket and i dont want to redo everything
wel lyou may have to , at least you know how to do it now
unlikely it works but try an easy out.
Emily's personal boyslave ![]() TSS: Rockin' the Bitches' Faces. B16A2 engine with: Short ram intake. DC Sport header: Ceramic coated, 4-2-1. Custom headerback exhaust with disconnected muffler. MSD Ignition system. (With Enkei wires) http://www.cardomain.com/id/imsoyesterday |
why dont you just get a bolt out its a drill bit that has the treds revered goin down left, (instead of right looking at a drill bit ud understand) so when you use a wrench to remove it the bit thinks its tightening but it actually removes the broken bolt
i bad its called a bolt extractor
Re: Re: how can i remove a broken valve cover bolt?
1992 Chevrolet Cavalier Z24 *R.I.P.* 3.1L MPFI (3.1 6cylinder Pushrod 12V) 1997 Chevrolet Cavalier Z24 *R.I.P.* 2.4L "Twin Cam" (2.4 4cylinder DOHC 16V) 2003 Honda Accord EX V6 - The new hotness |
I think you could get it done with the head still on the car, but I would be worried about fucking up my head, so I would take it off and have a machine shop take it out. You may be able to drive the car to the machine shop and they could take it out without pulling the head.
I may have missed something, but if it's just the head of the bolt that broke off, maybe you can get enough of a grip on the rest of it by just taking the valve cover back off and grabbing the broken bolt with some vise grips or needle nose pliers. There should not be much torque at all on the bolt with the head broke off unless it was cross threaded to begin with. Good luck.
easy out will do just fine.
www.cardomain.com/id/94caviguy |
the blot broke even with the head( if i take the cover off there would be no paret of the bolt out)
yes, take the valve cover off.. and use an easy out drill bit.. if that doesnt take it out you could drill it oversized then tap it and slap in a heli-coil.
shouldnt have to take off the head no matter what ya do. unless you take it to a machine shop. |
