Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 11-17-2005, 07:12 PM
Jiten42 Jiten42 is offline
sparkplug wire change, miss firing?? please help
we bought a car and basically tuned it up, all the works, oil, spark plugs and everything.. after i finished changing the spark plug wires, spark plugs, cap and rotor, the car started knocking like we dropped something inside but nothing was there. so we desided to take it to a mechanic and he changed the valve liftes, crank sensor, and all sorts of stuff.. but now its messing up again.. we just cant seem to figur out whats wrong with it. Today i went to auto zone and wanted to get the strobe to check the timing because the belt was changed to but someone mentioned that changing the gauge of the wire effects the computer and messes up the timing... ofcorce the check engine light was on and we kept reading it and it kept jumping from cylinder to cylinder and telling us that it was miss firing.. we installed a 7mm wire and the stock ones were 5mm. Does anyone know if this would cause the car to misfire?? the car drive but once its gets into higher rpm it starts to shake a little and sometimes it even cuts off..sometimes even the knocking sound comes back.. i just dont understand what the problem is.. btw its a V6 GT.. please help...
Old 11-17-2005, 08:16 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: sparkplug wire change, miss firing?? please help
i don't even want to kno what happened
Don't act like you don't love it.
503/2000
Old 08-09-2007, 01:07 PM
slash09 slash09 is offline
I'd check that you put the wires on the right cylinders/cap terminal.
too bad post whores like elchico boy can't offer any real help, they're just post whores.
Old 08-09-2007, 03:21 PM
808drifter 808drifter is offline
Lager wires shouldnt make a diferance seeing as how firing is controled by the motor/cap, not the ECU. Mabye the 7mm are bad. Try puting the factory ones back on and see if the knocking goes away.
BTW for someone whos been on here since 04, having only 6 post would make you a post n00b.
Old 08-10-2007, 06:27 PM
no... having only 6 posts means i don't reply to post just for ranking.
Old 08-10-2007, 09:59 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Well obviously your still a freakin noob when you keep bringing back threads from years ago... Seriously, start reading the last posted dates before bringing these things back from the dead!
Locked...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Closed Thread
