Old 11-17-2005, 06:57 PM
blc00k93 blc00k93 is offline
brake lights
I have a 2001 cavalier and the brake lights and the rear hazard lights do not work. The brake light on the trunk does work. All other rear lights work.
Old 11-19-2005, 05:02 PM
quake61's Avatar
quake61 quake61 is offline
Re: brake lights
check fuses and loose ground on tail lights
lets start from there
Old 11-19-2005, 09:25 PM
quake61's Avatar
Re: brake lights
i was thinking and u can also check the switch located in the back of the brake pedal
maybe is not working it looks like it can be that
Old 11-19-2005, 10:44 PM
DonSor DonSor is offline
Re: brake lights
You have three brake lights. Left, Third (Center) and Right. You said the left and right don't work but the center does. So it's not the brake switch. You also said your hazard lights don't work. If I'm not mistaken your hazard lights are the same lights activated by the directional signal switch. Are your directional signal lights OK? if they are then something is wrong with your hazard switch.
Old 11-20-2005, 02:23 PM
Re: Re: brake lights
Yes all other lights work just the brake lights and rear hazard lights do not work. If it was the hazard switch was inop. than the front hazards wont come on, correct?
Old 11-20-2005, 02:29 PM
I checked the fuses and they are okay. I'm not for sure on this but i don't think it would be a ground because all the other lights are operational. It is just the brake lights and rear hazards that do not work.
