Old 11-17-2005, 06:04 PM
scatfish scatfish is offline
Headlamp Replacement
Maybe I'm a moron, but I can't figure out for the life of me how to get to my passenger low beam to replace it. I've been pulled over so many times in the past two weeks because of the darn thing being burnt out. So, any help would be GREATLY appreciated. Thanks
Old 11-17-2005, 07:37 PM
DonSor DonSor is offline
Re: Headlamp Replacement
There is normally one bulb for the high beam and the low beam. You buy them as a unit. Assuming that your car is fairly new, open up the hood and reach down behind the lighting assembly and twist out and pull the light holder. Then unplug the bulb from the wiring. Do the reverse to install the new bulb.
Old 11-17-2005, 09:21 PM
baskerj baskerj is offline
On the TBs there is a soft plastic gromet behind each of the headlights. Remove that and you'll have access to twist the bulb out. Should take you less than 15 minutes...
Old 11-19-2005, 12:45 PM
ScarabEpic22 ScarabEpic22 is offline
Ummm, there are two bulbs for the highs and lows, TBs have never had a single bulb before. (The new body style ones, at least) Low bulb is 9006, high is 9005, fogs from 02-06 not SS are 893 (pretty sure on the last digit, migh be 890)
Also, if you are doing it for the first time, it is worth it to remove the three screws and pull the airbox cover off, makes it much easier the first time around.
-Erik
2002 Chevrolet TrailBlazer LT 4X4 -Summit White w/Oak interior
Many Mods, latest: EFILive tuned by (me)
Old 11-23-2005, 12:56 PM
yar02169 yar02169 is offline
Don't bother removing the airbox cover. The easy way to replace a bulb is to remove the housing assembly. Along the top of the housing assembly, on the left and right edges you'll see a metal tab that's bent at 90°. This tab is a locking mechanism for the housing assembly. The tab has a notch that acts as a locking mechanism, simply pull the tab a little so that the notch is free, then pull the tab in an upward direction. Do the same to the other tab. On my Bravada, there ia also one clip that needs a tug to be free. Now you can disconnect the two electrical plugs, and bam! the housing is free to be worked on. It is now easy to place the housing in a convienent location and replace the bulb. Re-assembly is just as easy as removal.
Old 11-23-2005, 03:15 PM
maxwedge maxwedge is offline
A990 racer
Actually you reach behind the lamp, in vehicle, pop the black covers off the back of the lamp and turn out the bulb, both sides.
Old 11-23-2005, 07:08 PM
KahneFan's Avatar
KahneFan KahneFan is offline
Go to Walmart, I think install is free ;-)
