Old 11-17-2005, 05:19 PM
SniperX13's Avatar
SniperX13 SniperX13 is offline
Send a message via Yahoo to SniperX13
Where is the Brake Relay Switch
Well, both of my brake lights went completely out, but the tri light still works. I still have turn signals and lights when the headlamps are on.
so, I am thinking that the brake relay has gone bad or loose.... but
where exactly is it?
I have a 98 Taurus SE with the 24v V6.
thanks.
"Who are we to judge those, when we ourselves are afraid to be judged."
Old 11-17-2005, 11:41 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Where is the Brake Relay Switch
There is no relay for the brake lights. There is just a brake pedal position switch located near the brake pedal. When you press on the brake pedal, the switch contacts close and provide battery voltage to the brake lights.
The Center High Mount Stop Lamp (CHMSL) uses the same switch as the tail lights, so the switch must be okay. Have you tried using a test light at the bulb socket?
Are you sure you got the correct bulbs and put them in properly?
-Rod
Old 11-18-2005, 06:36 PM
SniperX13's Avatar
Re: Re: Where is the Brake Relay Switch
-Rod
Yes, I am sure of the bulbs. There is only one way for them to go in.
I bought the Stop Light switch ($20.00) at the ford dealership.
I replaced that and nothing happened. It's going into the dealer next friday for a diagnostic to be run to see if they can chase down the culprit.
