2001 Cavalier Stalling
I have a 2001 Cavalier that will stall when slowing down. This happens on the freeway or coming to stop. It only happens when letting off the gas. It will start back up but is getting more frequent. I have 31,000 miles on it. Can you help?
Re: 2001 Cavalier Stalling
your either not getting fuel or a spark... do the cheap stuff first.. fuel filter $8 Fram, spark plugs $10 Bosch platinum 2
Re: Re: 2001 Cavalier Stalling
i actually had the same problem on my mystique but before i got to fix it got wrecked, so i know what ur talking about
Dont get Bosch. I had them in my camry and they sucked. Well IMO anyways. I would go with NGK. You can get them pretty close to the same price as Bosch. I had that problem before. two things u should check/do.
1. Get an oil change. I changed the oil and it worked fine for a while 2. Check fuel pressure.
You to read thishttp://www.sherdog.net/forums/showth...1&page=1&pp=20 |
Try replacing the Throttle Position Sensor or MAP Sensor.
Fredo |
its the tps, i garuntee it
