Old 11-17-2005, 03:30 PM
tripod12133 tripod12133 is offline
Send a message via AIM to tripod12133
Backwards fuel filter ?
okay, I have a 1988 camaro, v6 TBI. I put a new fuel filter on it and it seems as though around the same time i put it on, i started getting worse gas mileage. i used to get about 270 per tank. now im just getting 230 or 225 per tank. I dont know if a backwards fuel filter will do that or not. please help.
Old 11-27-2005, 08:34 AM
demon9766 demon9766 is offline
Send a message via Yahoo to demon9766
Re: Backwards fuel filter ?
Well if the filter is backwards it won't get the fuel flow that it needs but i would think that you just need a full tuneup.
This is what 500 plus hp looks like.CNC ported AFRHEADS WITH 2.02 INT 1.60EXH,210 intake runners 74cc chambers, 750 speed demon carb,weiand intake,comp cams 292 with .501/.501 lift ,4340 forged crank,eagle H-beam rods duroshield bearings,KB forged 10 1/2:1 pistons,headers with 1 3/4 primaries ,MSD 6AL,comp cams pro mag1.6 rockers,holley blue pro-series pumps,MSD billet distributor.All stuffed into a 355.[img][/img]
Old 11-27-2005, 09:03 AM
flatlander757 flatlander757 is offline
Send a message via AIM to flatlander757
If the fittings are anything like other cars I've seen, there's no way you could install it backwards short of cutting off and replacing the fittings on each end
I'd look somewhere else.
Go get a scan and see if any codes show up, I thought it was my fuel filter giving me 12mpg, but turns out it was the EGR valve(which I still haven't gotten around to replacing )
-Tony- Sold my Z28 looong ago. Now sporting an '03 TJ.
Old 11-27-2005, 09:57 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
If it is the gm filter with the same fittings on both ends they will have a arrow to should you the fuel flow direction. But I dought that being on backwards would be your problem.
MT
