Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 11-17-2005, 02:28 PM
crzyCollegeKid crzyCollegeKid is offline
thinking of buying 2001 Spyder
hey guys, i'm thinking about buying a 2001 Mitsu Eclipse Spyder Convertible. i'm going to go check it out tomorrow, and i wanted to know what were some known issues so that i could check them out when i got there. any help would be greatly appreciated. i already ran a carfax report on it and it came out clean.
Not-named-yet:
2011 Hyundai Sonata SE w/Sunroof and Nav in Iridescent Silver Blue Pearl
Claudia (traded-in):
2003 Mitsubishi Eclipse GTS: Pioneer Speakers All Around, Kenwood MP3 Deck, Clarion Equalizer, Boss 4ch. 800W amp, 2 Dual 12" subs with Dual 500W amp, XM Roady2
R.I.P. Jessica
1997 Honda Prelude: AEM CAI - Exedy Full Face Organic Clutch - XACT Streetlite 12.5lb flywheel - DC Sports Short Throw Adapter
Old 11-17-2005, 03:53 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: thinking of buying 2001 Spyder
**if its a 5 speed, listen for a rattling noise at idle, that's TOB rattle and you don't want that (if its a 5 speed marked **)
make sure the foglights work
make sure the sunroof doesn't shudder
uhhhhhhhhh, just standard stuff otherwise
**o0o make sure there isn't a warped flywheel/pressure plate, or get a written warranty for that, if someone before has revved it up and dropped the clutch the flywheel is WARPED and you will most certainly want a new one
------symptoms of a warped flywheel are shuddering after cold start, but only when clutch is partially engaged
vibration during shifting gears and hanging onto the clutch
trust me it sux to have that thing warped ^^
if its a sportronic trans, make sure that it is what you want it to be, the sportronic won't have the same effect as your "WEEEE-tec"
scrapes under bumper
curb rash on wheels
tread on tires...
standard stuff
take it to a mechanic and have it checkd out too, never a bad thing to do that
Don't act like you don't love it.
503/2000
Old 11-17-2005, 10:38 PM
thx for the help
thx mate
yea, i know how much a fucked up clutch/flywheel assembly can be. the clutch on my prelude started scraping the inside of the flywheel and had to be replaced. $500 for the parts and another $400 for the damn job. but anyways, you didn't mention anything towards convertibles...what should i look for there?
Not-named-yet:
R.I.P. Jessica
Old 11-18-2005, 08:42 AM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
just make sure the convertible doesn't leak.
Old 11-18-2005, 11:39 AM
Sleepr awd's Avatar
actually a little leak is damn near unavoidable, make sure its not really bad though, my dad's 97 spyder had a leak on the passenger side and he bought it brand new
503/2000
Old 11-18-2005, 10:48 PM
damn guys...i bought a 2003 Eclipse GTS today and on the test drive it didn't rattle at all. The sunroof shuddered a lil when opening, but closed fine.
Then when i drove it off the lot and i was driving it around, i heard it, the rattling, which goes away when i push the clutch in. i bought a 2 year warranty on it, bumper to bumper and i have 3 days to return it, i'm already in love with it, don't know what to do, are the tranny and sunroof problems fixable?
Not-named-yet:
R.I.P. Jessica
Old 11-18-2005, 11:32 PM
cficare68's Avatar
cficare68 cficare68 is offline
That is probably the clutch pressure plate rattling. Mine does that as well. I think that it is a common problem with all the 3g eclipse. Not a major problem and doesn't affect anything else
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads.
Old 11-19-2005, 09:10 AM
yea...it might not be something serious...but it is a car i just purchased and that sound is very annoying and embarrasing, can it be fixed?
Not-named-yet:
R.I.P. Jessica
Old 11-19-2005, 01:36 PM
Sleepr awd's Avatar
it can be fixed, all stock style TOB's need to be replaced w/ aftermarket ones or they will rattle, i just replaced my clutch w/ a factory like one, and it STILL RATTLES everyonce in a while, it only gets louder and more annoying, but a Spec stage 2 or any other higher performance aftermarket clutch will not make the noise, so if your modding it, you'll be cool<< when you do replace the clutch, i recommend the spec alum. flywheel too, its awesome
as for the sunroof, it only gets worse, there is a factory replacement of a newer design (you'd have to ask for it) , if you can get it, the older style rails will always shudder, so get them to replace that while you can!!!!
i dont' think there is anything else, but those GTS spyders are AWESOME!!!
503/2000
Old 11-19-2005, 01:53 PM
good luck with getting the TOB replaced. i can guarantee you that they will tell you there is nothing wrong and they won't fix it.
Old 11-19-2005, 02:13 PM
TOB = throw out bearing?
Not-named-yet:
R.I.P. Jessica
Old 11-19-2005, 03:03 PM
cficare68's Avatar
My sunroof is horrible now. I have to push up on it for it to even go back
Old 11-19-2005, 04:53 PM
Thruster Thruster is offline
Send a message via AIM to Thruster Send a message via MSN to Thruster
Re: Re: thinking of buying 2001 Spyder
same. mine comes off the tracks a lot too.
Old 11-19-2005, 05:19 PM
just made a bad discovery...i floored the car and was taking it all the way up the tach, and before it even hit the redline, i heard a very weird sound like if the clutch seperated from the flywheel and the motor kept revving up...makes me think its the pressure plate thats fucked too...
Not-named-yet:
R.I.P. Jessica
Old 11-20-2005, 12:26 PM
Sleepr awd's Avatar
uhhh oh, if it was a new clutch you have to break it in or it will slip
get teh sunroof rails replaced NOW!! did you get it from a mitsu dealership or otherwise? mine hasn't shuddered or juddered or whatever ever since i got it replaced its a beautiful thing
503/2000
