Old 05-29-2002, 10:40 PM
crX-RATED crX-RATED is offline
Send a message via AIM to crX-RATED
JDM B16 Distributor
as the title says, i need a distributor for a JDM B16. if anyone has one they are willing to sell, hit me up, or if you know if there is a USDM replacement, that would help too. i heard you can take a 94 GSR dist. and rewire it, but i dont know how. can anyone help??
Too many kids w/ too much NOS.....
Old 05-30-2002, 01:32 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
I can get you a brand new one ex Japan, should cost about US$600
(that is not a Typo)
Otherwise you should be able to use one from a B16a in the Del Sol, but I have heard the one in the '99 Civic Si is differnt.
(you can use it, but you need to change the VTEC solonoid as well)
Otherwise one from an early B18c or B17c powered GSR integra will work.
However altough it will fit and the car will run I do wonder if the ignition map is the same. Its possible that by useing it you might not be getting the full potential from the B16a.
Old 05-30-2002, 11:41 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
600 dollars!!!??!! Man thats alot. Well anyways my friend got his JDM distributor rebuilt. So you can rebuild yours.
Old 05-31-2002, 02:56 PM
well, the dist. works fine, it's just the #1 cylinder position sensor is out, so my check engine light is up, but i still get VTEC and everything. anyone know how to fix the sensor by itself?? will rebuilding it fix it??
Old 05-31-2002, 07:06 PM
shatshadarach shatshadarach is offline
all the electronic stuff should be the same as any 90-93 teg or even 89-91 civic, my ignitor offa my d series was the same as my b16a one, cept my d series one wasnt broken...
Old 06-04-2002, 09:47 PM
91SIR 91SIR is offline
Moppie what is the part number for that distributor? is it TD18U
thanks
jdm h22 help sanchezjarodsdad JDM Motor & Parts info/chat 4 04-09-2009 05:14 PM
Difference between JDM b16 and USDM b16 HondaDriver82 JDM Motor & Parts info/chat 6 10-17-2004 09:55 PM
1st JDM B16 160hp other gens JDM B16a a2 a3 170hp s14arb25det '88 - '91 Civic | CRX | Wagon | Shuttlee 4 12-14-2003 12:12 AM
B16 distributor Kunundrum '88 - '91 Civic | CRX | Wagon | Shuttlee 1 06-21-2003 09:32 PM
B16 distributor riggins10ai Engineering/ Technical 1 12-05-2002 10:46 PM
