Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 11-17-2005, 12:53 PM
RickAM RickAM is offline
Turn key and nothing....well sometimes......
Hi all:
I just purchased a 1999 CR-V and have one annoying problem. Since it's a 5 speed I need to depress the clutch in order to start. Sometimes it'll start and sometimes it wont. Every once in a while when it wont start(or crank) I'll put into or out of gear (with the clutch depressed) and that will allow it to start...but this is not always the case.
Any clue as to where to look first? Ignition switch or clutch/start switch or ??? BTW, anyone know where the clutch switch is?
Thanks!
Old 11-17-2005, 09:04 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Turn key and nothing....well sometimes......
when it happens, it just doesnt crank or it does crank? when it happen, you have power?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
lorunner lorunner is offline
the clutch switch is typically on the clutch pedal bracket under the dash.
Do any or all lights on the dash come on when you try to start?
May be a sign of a starter going bad also.
Stop asking me about radio codes I cant get them anymore!!!
