Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 11-17-2005, 12:24 PM
tgwright tgwright is offline
DRL module
My DRL's have been inop for a year or so now, and I recently went through the troubleshooting procedure in the GM shop manual. It appears that I need a new DRL module, which is simply a circuit board. Has anyone else found that this is the reason for the DRL's to fail?
Old 11-20-2005, 06:26 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: DRL module
What year?
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-20-2005, 06:47 AM
Sorry. It's a '99.
Old 11-20-2005, 06:57 AM
GMMerlin's Avatar
I know stuff
Re: DRL module
Usually the diode is what goes bad on these..
GM WCT
PM Me for details
Old 11-20-2005, 08:18 AM
Re: Re: DRL module
I assume you mean D203? That's what I first suspected, but I'm getting power to the DRL relay terminals which supply the voltage to the DRL's, and the relay is downstream of the diode. If the diode has failed will it still allow voltage to the relay terminals (G6)?
Old 11-24-2005, 10:08 AM
Jeremy-WI Jeremy-WI is offline
Re: DRL module
My truck showed voltage at the relay terminal(about 9 volts) when the diode was bad, never did bother to check voltage again after diode was replaced and my DRL's worked again
Old 11-24-2005, 05:21 PM
777stickman 777stickman is offline
Re: Re: Re: DRL module
D203 is correct. When the diode fails it "usually" stops all voltage feed to the relay. Is the DRL indicator lamp in the instrument panel on with the key in the "run" position and the light switch off and the parking brake released? If is "not" on then suspect the module, light switch or parking brake switch. If it's "on" and you've determined the diode is ok, then suspect the relay. It's a cheap and easy trouble shooting replacement. Let us know............Steve
Old 02-01-2006, 06:16 PM
wonder squirrel wonder squirrel is offline
Re: DRL module
Bringing this thread back for a question.
How do you remove the diode assembly from under the dash? Does it require taking the dash apart? I can see the piece, but can't feel any bolts/ screws holding on
Old 02-01-2006, 06:44 PM
Re: DRL module
On my '99 I found that the easiest thing for me to do was to simply bend down the two tabs on the mounting bracket and slide the diode out the bottom. I had to flex the bracket a little to get the diode to clear some of the structure there, but the diode slid right out. Then unplug the old, plug in the new, and slide it back into place in the bracket. Then bend the tabs back over so the new diode won't slide out.
Old 02-01-2006, 06:46 PM
Re: DRL module
So theres no bolts or screws holding it into place? Only the bracket? I'll have to go give it a shot and see if I can get it out that way, thanks for the help
Old 09-22-2006, 08:39 PM
bigrockk's Avatar
bigrockk bigrockk is offline
07 2500hd classic
Re: DRL module
Hello,
I know this thread is old but I was hoping someone could tell what the diode looks like.
Does it have fairly large heat sinks (fins) on it?
Thanks in advance
Old 09-23-2006, 07:31 AM
Re: DRL module
The diode is roughly the size and shape of a pack of cigarettes and is located to the right of the steering column just under the dash. I found it necessary to remove the lower dash to access the diode.
Old 09-23-2006, 07:32 AM
Re: DRL module
And yes, it does have heat sink fins around it. In fact it is mostly fins.
Old 09-23-2006, 09:48 AM
bigrockk's Avatar
07 2500hd classic
Re: DRL module
Thank you for the info and a quick reply.
At least now I know I am looking at the correct component.
I can see the diode with the lower dash in place but it will have to be removed to do the replacment. I will tackle today and see how it goes.
Thanks again.
Old 10-01-2006, 05:50 PM
bigrockk's Avatar
07 2500hd classic
Re: DRL module
Hey I just thought I would let you know that I did get the Diode changed and the DRL'S are back to normal.
I used "tgwright's" method for replacing it and it worked great.
Thanks again!
