Old 11-17-2005, 10:05 AM
vicchang vicchang is offline
Driver's window air leak / wind noise
92 Accord. The window tilted about at the last .5 inch of travel when closed. This left a small opening at the rear upper corner between the glass and the rubber seal. Anyone has this problem? What's wrong with it? How do you fix it?
Thanks.
Old 11-17-2005, 10:03 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Driver's window air leak / wind noise
If you can lift it into position without interference, then there is probably just a rubber or plastic bushing that popped out where the window sits in the lift, letting it sag.
Pull the interior panel off and have a look. You'll see what's happening.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
