Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 11-17-2005, 09:30 AM
winston30 winston30 is offline
How to replace a Crankshaft positioning Sensor in a 1999 Sonata
Can anyone help me with instructions on how to replace a Crankshaft Positioning Sensor in my 1999 Hyundai Sonata.
Old 12-11-2005, 04:45 PM
quickywd01 quickywd01 is offline
Re: How to replace a Crankshaft positioning Sensor in a 1999 Sonata
Which engine do you have? I'll cover the 2.4l 4 cylinder. But before I do heres somethin you should know. DESCRIPTION:
The 1999-2000 Sonatas Camshaft Position (CMP) Sensor is incorrectly called the Crankshaft Position Sensor in the Parts Catalog.
The table below lists the correct part number and description for the Camshaft Position Sensor and the Crankshaft Position (CKP) sensor for the 1999 and 2000 Sonata.
Table 1: Correct Description for CMP CKP
PART NUMBER /PART DESCRIPTION/ MODEL- ENGINE/ PARTS CATALOG PAGE
39310-38050
SENSOR -- CAMSHAFT POSITION
99/00 2.4L I4 SONATA
31
39310-38060
SENSOR -- CRANKSHAFT POSITION
80
39350-37110
99/00 2.5L V6 SONATA
34
39180-37150
81
NOTE
The descriptions Camshaft Position (CMP) Sensor andTop Dead Center (TDC) Sensor are interchangeable. They describe the same sensor.
The above description error will be corrected in future Parts Catalogs.
Ok and now for the replacement of the sensor: On the 4 banger the crankshaft position sensor (CKP) is located right above the cranshaft pully and to the right. Here is a picture, the top picture is the camshaft sensor, the one you're looking for is the one in the bottom pic
Heres a pic of where it is located on both the 2.4l and 2.5l engines. Heres the 4 cylinder 2.4l the sensor is 10 on the pic
ad heres the v6 pic and its also #10
Nissan, Subi, Yoter, Ford
