Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 11-17-2005, 08:28 AM
JDMh22a Lude JDMh22a Lude is offline
H22a swap
Hey guys i just bought a 1995 prelude si with a blown motor, perfect for my H22a swap anyway i just wanted to know what my best options are to get the most power from that fire breathing h22. any help would be appreciated.
Old 11-17-2005, 11:54 AM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Re: H22a swap
#1. Turbocharge -- Turbo, manifold, wastegate, intercooler, piping, complete ECU retune...
#2. NA -- High compression pistons, valves, springs, cams, complete retune...
Personally I enjoy natural aspiration, but if you are on a budget then a turbine is the way to go. Turbos are simple to install with the motor on or off, but an NA tune will need the engine out and apart. It is very easily to extract power from a turbo, I have seen examples in the high 12's from a simple turbocharger installation.
Good luck
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 11-21-2005, 10:53 AM
AllmotorBB6 AllmotorBB6 is offline
Re: Re: H22a swap
Good luck
you'll need iron ductile sleeves in order to run forged pistons....cant forget that part.
OR you can run an h23/f22 crank with f22 rods and type S pistons. That should put you in the 12+ area in compression. Then a nice cam setup and you will be good to go.
