Old 11-17-2005, 08:12 AM
2000silvowner 2000silvowner is offline
Question system upgrade advice
Hello all
I have a 2000 silverado regular cab with the factory cd player, 6.5 door and 4X6 rear pillar speaker setup.
I want to get a head unit that has the aux input and hopefully a usb input on the front that plays mp3 wma and cd. The only unit I have seen that does this is a VR3 unit that I believe is mfg by Durabrand which I am wary of (poor quality). 20W per channel is fine
I wanted to avoid amps but also realize I may need to add some bass with the limitations of the 4X6 pillar speakers
As for speakers I am wide open as to the size and placement but I do want the truck to still appear mostly stock and not lose any interior space (not much there to start)
Tweeters for the A pillar area are also a consideration if any of you have suggestions
Anyway sorry for the long message but I wanted to give you enough info.
Thanks in advance for the help.
Old 11-17-2005, 06:04 PM
germanyt germanyt is offline
Re: system upgrade advice
http://www.infinitysystems.com/carau...y.aspx?Ser=KAP
http://mtx.com/caraudio/products/amp...hunder5604.cfm
http://www.pioneerelectronics.com/pn...552934,00.html
this might help you out.
(2) RE SX 15s (www.reaudio.com)
~6.5^3 net @ 35 Hz (polyfilled to increse vol. & lower tuning to 32 Hz)
(2) eD Nine.1s (www.edesignaudio.com)
1 Optima yellow top (www.optimabatteries.com)
1 Optima red top
200 amp alt (www.dbelectrical.com)
eDead V1SE2 250 sq ft
Big 3 (1/0 awg)
Pioneer DEH-P650 (www.pioneerelectronics.com)
Infinity Reference 5 1/4 comps (www.infinitysystems.com
Infinity Kappa 6x9s
MTX Thunder 3404
Power Acoustik TFT/LCD
Pyle DVD/CD/MP3/WAV/WMA player
