Old 11-17-2005, 01:47 AM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Project update: 3inch exhaust...
Fist off... hello "newbies", there seems to be quite a few since i've last been on here on a regular basis.
Shouts out to 89IROC, apparently we both have been gone for some time.
The Car
running good, strong as hell. tranny shifts really quick. was playin around with turbo WRX and turbo Evo one night, was neck and neck with both from 20mph up to somewhere around 115mph. Don't be diasappointed, that is only temporary. As soon as I get my new exhaust on there, few cars will be able to keep up. I still have the tiny ass V6 exhaust and y-pipe on there. I estimate 260-280hp right now. after the new exhaust and tune, 360-420hp.
Still haven't done a whole lot since last update, 2 jobs and upper level computer science classes are eatin up all my time.... and social life for that matter.
Just bought TCI throttle valve (click) to increase my top speed. Next on list TCI 2200stall converter (or transbrake, if I can find one), control arms (wheel hop is tremendous right now), subframe connectors, and posi-trac differential.
Those of you who have 3" exhaust systems, tell me what your setup is like. All I could find was a catback from SLP and it was $500. not interested in that, I need full exhaust system. I'm planning on custom making a 3" mandrel bent system by buying the pre-bent pipe from summit or classictube.com and cutting/welding them myself. There are pics of the design below. And this is going to cost a lot less than $500. I already bought the flowmaster super 40 series muffler (pic below).
Don't know where the paint is going yet. I printed out some pics of my car and I got some colored pencils to design the paint scheme Chip Foose style. we'll see how that turns out.
I would have videos but my sister has my digital camera 120miles away. I'll post some next week. That's all for now.
WHAT IT LOOKED LIKE THIS TIME LAST YEAR
SUPER 40 SERIES MUFFLER - 3"IN / 2.5" DUAL OUT
THE DESIGN
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 11-17-2005, 01:58 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: Project update: 3inch exhaust?
Definately go 3". My magnaflow LT1 catback (will bolt up fine to a 3rd gen with just some minor modifications) cost me $320. If you want performance you don't really want flowmaster, sorry to break it to you... they sacrifice performance for sound which is fine with some people but not cool with me. Aside from that, you pretty much wanna come from teh y-pipe to the cat if you're keeping one, then a S-type bend to get the exhaust in the driveshaft tunnel, run it straight back there, then over the rear pretty much how it's layed out there. Really follow the same path as the stock system.
good luck
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 11-17-2005, 02:08 AM
the design I made does follow the factory routing. flowmaster performance just depends on which muffler you go with. the camaro/firebird muffler (which I have installed right now) is so so on performance. but you can get race mufflers and one chambers that are low-no restriction. just depends on what you buy. the one in the pic is a 2-chamber super 40, not the crossflow camaro/firebird muffler. it will perform well without being ridculously loud. but loud enough to scare ricers... haha.
I'll look at the maganflow catback...I'm not puttin a cat on though.
Old 11-17-2005, 09:10 AM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Do you already have headers? Long tubes? On my car a custom 2.5" y pipe was fabed up(thats what it looks like anyways) and then its 3" from the y back. The car has what i think is probably an 80's series flowmaster. Its real quiet. I need to fix that...... But I want long tubes!
Maybe you have posted it before but what are the detailed specs of your engine? Type of crank, year of block etc....
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 11-17-2005, 10:35 AM
Headeam headers (shorties), (1979) 350 block stock internals, vortec heads, Edelbrock performer rpm vortec intake, comp cams 268 cam, edlebrock 750cfm carb, high volume oil/water pump.
Old 11-17-2005, 11:59 AM
no cat, good to hear... at least you know what you're doing with the flowmasters, i hate when people go "but their name is flowmaster! it has to be the best flowing!"
as long as you follow the stock path you should be good to go
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 11-17-2005, 10:14 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
sounds like a solid plan, although i think the 100hp increase from an exhaust and tuneup is a bit optamistic. although if anything you went concervative on the current power with that setup, id say youre pushin at least 300hp right now.
my two cents on the exhaust, which wont effect performance, but im a sucker for symitry, so i like the 80 series muffler that has a pipe on both sides of the car, but to each his or her own.
now for the rational side, you say youre not running a cat, we all know my view on that so i wont use the soap box, but as a suggestion, make sure strait pipe A has a flange in the right spot to use the exhaust hanger off the transmission tailshaft, otherwise its going to sag in that long stretch from the headers to the rear hangers, and your exhaust will hit every speed bump you pass over. which tends to put a big hole in it.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 11-17-2005, 10:45 PM
sorry but I have to call BS on that, the pipe will hold itself up just fine. I actually took that hanger off since it weighs about 10 lbs... havent hit on anything, and i go thru shitty NJ raods every day. Whter I have my cat or my bullet muffler on replacing it (have flanges so theyre interchangeable), same thing.
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 11-19-2005, 03:06 PM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
I think u can actually have some of the pipes bent a little so they are oval in shape to gain some clearence..
Also why no try installing two 3inch 40 series mufflers with a second y pipe and 4 2.5 inch pipes out. That should make it real deep, but not to annoying?
Old 11-19-2005, 03:41 PM
That would be a lot of extra work and money, and i dont see it being worth that extra bit
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 11-19-2005, 05:25 PM
ROUDA's Avatar
ROUDA ROUDA is offline
Why Dont You Go With The (80)flowmaster Muffler That Is Set Up For A Camaro. You Also Have The Dual Look On Each Side Rather Then Two Pipes On The Same Side.
Old 11-19-2005, 06:50 PM
Banned
Flow issues
Old 11-19-2005, 06:51 PM
Banned
go twin 40ies, like bimmer people do
Old 11-19-2005, 08:02 PM
89IROC&RS's Avatar
my exhaust sag may have been due to the fact that none of my pipes are welded. just pipe clamps all the way round. but i definatly had the sag on the IROC, i had to take the trans mount off my RS and put it on the IROC to pull the exhaust back up and away from the asphault. and um... maybe you arent sure what im talking about, cuz it might weigh half a pount at most, no where near 10 lbs.
Old 11-19-2005, 09:07 PM
ROUDA's Avatar
What Do You Mean Flow Issues.
