Old 11-16-2005, 10:22 PM
z28 boy's Avatar
z28 boy z28 boy is offline
Send a message via AIM to z28 boy
700R4 to 4l60E
are the internals the same? like would the clutches and steels and bands be the same? I need to rebuild my tranny and was wondering if ordering a 700R4 kit would work. I see that TCI offers a rebuild kit with a shift kit included but it only says 30 splined 700R4, I know the 4L60E is based on the 700R4 and is also 30 splined.
R.I.P. Andy, A great guy and an even better friend.
2000 Z28 A4:
Patriot 226 cam, Comp 918's, Comp Ti retainers, HSW 100 shot, Vig 3600 stall, Richmond 3.73's, 2.5in TD's w/ H-pipe & 1-chamber flowmasters, 160* stat, TSP Lid, K&N filter, MSD wires.
Buried Needle Racing!!!
Old 11-16-2005, 10:38 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 700R4 to 4l60E
The plates should still work - they're the same. The valve body gaskets, however, will not.
Old 11-17-2005, 12:25 AM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: 700R4 to 4l60E
yea... those are the same trannys, the difference is just in how they are controlled (valve body), electronic and mechanical.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 11-17-2005, 01:54 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: 700R4 to 4l60E
TCI should have a kit for the 4l60e tranny. Ive read places that the rebuild kits for them are very year to year specific. Little minor things are different or something. Id give TCI a call or email and see what you need.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
