Old 11-16-2005, 09:31 PM
blazer king blazer king is offline
Send a message via Yahoo to blazer king
Question V8 engine swap
I own a 1988 6 cyl. 4.3 fuel injected chevy S10 Blazer. I need some info, on what chevy models,years,type engines can I drop in it.
Old 11-19-2005, 12:41 AM
OverBoardProject OverBoardProject is offline
Banned
Re: V8 engine swap
Try sticking to an 88 full sized motor. Preferably 3/4 ton since it shold be a 350.
It'll be the easiest in the long run, and a good motor.
Old 11-19-2005, 02:58 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: V8 engine swap
get a 350 from the same year as your dime, as overboard said, it will be the easyest, for parts you need search the board, rlith has listed it in detail several times, your looken for a total around 2500 to 3k
Old 11-19-2005, 07:57 PM
cg13 cg13 is offline
Lightbulb
check out a web site called Jagsthatrun.com
Won't help on the year or model for motors, but will give you lots of info on the swap.
Old 11-19-2005, 09:37 PM
Re: Re: V8 engine swap
So will the parts like a starter and alternator off of my 2.8L fit on a 350
Old 11-19-2005, 10:14 PM
Banned
Re: V8 engine swap
Alternator, Yes.
Starter dono, but probably.
Your best off to just buy a complete good runnng, good driving full sized parts truck
Old 11-20-2005, 03:24 AM
Re: V8 engine swap
2.8???????// you said you had a 4.3, 2.8 parts dont switch to a 350, only 4.3 parts, take 4.3 divide by 6, multiply by 8, and that should make sence as to why the parts are intercangable, including the ring gear/flex plate, a 4.3 is a 350 (5.7) minus 2 cyl.
