Old 11-16-2005, 08:01 PM
bjkroll bjkroll is offline
Send a message via AIM to bjkroll
Exclamation Big problem, please help! (transmission mount/pan)
Alright, something went wrong. I was in the process of removing the bolts from my transmission pan, and noticed a large bar leading across the lower end of the trans pan. I was in the process of removing, when I realized it was the transmission mount! I was always under the impression that the transmission needed to be held up by a jack whenever the mounts removed. I see no way at all to access all the bolts in the pan without removing that cross-bar.
Is it safe to remove the mount while removing the pan? I already did one screw, and it shot out.. didn't seem safe.
EDIT:
Argh, I supported the trans near the u-joint, which took a load off of the trans. Nothing damaged (thank god). Still struggling with the mount/crossmember. Argh, rust.. solid rust, small arms
I'll be replacing the mount and bolts and whatnot.. Sadly, I need to drill out half a piece of rust, and re-thread.
Old 11-17-2005, 03:59 PM
Mailt4 Mailt4 is offline
Re: Big problem, please help! (transmission mount/pan)
USE THIS AS YOUR OWN RISK
Get a 2X4,put it across the oil Pan, jack it up SLIGHTLY enough to take the pressure off of the Mount and support it then remove the Mount, after you remove the Mount, support the Trans at the mounting bolts area then remove the Pan.
When you replace the filter ( I assumed ) reinstall the Pan, support the Trans with the 2X4 at the Pan and put you mount back together.
BE SAFE
IF IT'S TOO LOUND, YOU ARE TOO OLD
Old 11-17-2005, 09:04 PM
Re: Re: Big problem, please help! (transmission mount/pan)
BE SAFE
Woa, thats way outta my league. I get scared enough jacking up a car (I know of a few that have died this way ). Thanks for your advice tho.
Old 11-17-2005, 09:09 PM
driftinggrifter2's Avatar
driftinggrifter2 driftinggrifter2 is offline
Send a message via AIM to driftinggrifter2 Send a message via MSN to driftinggrifter2
If you dont want to do it the way he mentioned the only other way i can see it being done is taken to a shop or find a friend that would be willing to do it for you.
Old 11-18-2005, 02:49 PM
Hmm, im doing something similar to what he mentioned. Im waiting to get this bolt removed from the frame (broke off, dont have the tools) and I really think I can handle it from there. Thanks everyone!
