Old 11-16-2005, 07:02 PM
ARK51294 ARK51294 is offline
wont start
2000 XJ classic 4.0 I think . Jeep will turn over no problem no check engine lights are on. When you turn it over and give it gas it will start. It wont stay running unless you give it gas. Once you let off the gas pedal it dies again. Then it will finally give and stay running. This is the second time it has happened. any idea? Thanks
Old 11-16-2005, 07:24 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: wont start
Idle control motor, MAF or Throttle position sensor are some things that come to mind. I would suggest having the codes pulled anyway(Not all trouble codes request that the check engine light be turned on).
Old 11-17-2005, 10:35 AM
Re: Re: wont start
No codes where there Had it checked at autozone today.
