Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 11-16-2005, 06:51 PM
element115 element115 is offline
Question heated seat filters
I have a 2003 LS and would like to change the filters for the heated seats. Does anyone know what is involved to do this. I have been told that you have to remove the seats!! It cost over $100 to have the dealer do the job.
Old 11-16-2005, 07:49 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: heated seat filters
Seat filters?!?!? Like Activated Charcoal or what, I'm curious.
Old 11-16-2005, 10:04 PM
Lead Foot Lead Foot is offline
Huh? Are you talking about the heating element (see below diagram 1)?? ... Or maybe the heating ducts or cabin filter (diagram 2)?? Let's narrow this down so the dealer doesn't rape you!
Diagram 1
Diagram 2
Old 11-17-2005, 08:42 AM
CGGorman's Avatar
CGGorman CGGorman is offline
Removing car seats is a simple task. I used to remove the seats in my Jeep and Shadow to remove and hose off the entire carpet in the driveway!
Chris Gorman -LLSOC Forum Moderator-
2000 LS8 sport (lowered 2", LLSOC Intake, Magnaflow catback, tint, more..)
Old 11-17-2005, 10:55 PM
Re: Re: heated seat filters
Diagram 1
Diagram 2
The dealer said the filters filter the intake air for the motors. I assume they circulate the heated air?? Thanks for the diagram, but does it show any filters? The cabin filter is accessible from the hood and is located near the firewall (passenger's side). I've changed this filter once.
Old 11-17-2005, 11:01 PM
I might give it a try. Only, where in the heck are the filters located?
Old 11-17-2005, 11:04 PM
They are apparently under the seats and filter air for the motors that circulate the air.
Old 11-17-2005, 11:52 PM
The things Lincoln comes up with to make more money with sensless, retarded things....that just.....nevermind
Old 11-17-2005, 11:54 PM
Why do you need to change them(if they indeed exist)?
Old 11-18-2005, 09:08 PM
Re: Re: Re: heated seat filters
The seat heaters are elements which derive warmth via electrical current (similar to an electric blanket or heating pad). I've never heard of heated seats utilizing motors, filters and hot air. I think you got fed some bogus info.
Old 11-20-2005, 11:25 PM
Agreed with ^him^
l l
Old 11-21-2005, 02:44 PM
CGGorman's Avatar
Re: Re: Re: Re: heated seat filters
If these are the heated AND cooled seats, they do indeed use blowers. The seats use a Peltier device to electrically generate both warmed and cooled air, so the system doesn't have to wait for the engine in either case. A blower moves air across the Peltier and then out through the perforations in the seat. The system is manufactured by Johnson Controls.
Old 11-21-2005, 06:22 PM
Re: Re: Re: Re: Re: heated seat filters
These are heated and cooled seats. Do you know where the filters are located?
Old 11-21-2005, 09:42 PM
Ah-ha! Probably would have helped if he mentioned the perforations ... I still have no idea since I don't have those type of seats; only heated.
Old 11-22-2005, 09:56 AM
CGGorman's Avatar
Re: Re: Re: Re: Re: Re: heated seat filters
I know the blower is under the seat bottom and has a flex duct that runs up into the back. I would imagine there is a intake plenum that the blower is mounted in. Should be relatively easy to locate with an inspection mirror and a flashlight.
I have an ancient LS w/o any form of seat temp control, so my experience is purely anecdotal.
Here's the best picture I've seen of the ducting:http://www.llsoc.com/V2R1/Resources/..._intro_23a.asp
