Old 11-16-2005, 07:32 PM
mybigredford mybigredford is offline
Unhappy vacuum ball in 92 blazer?cant find?
where is the vacuum ball located in my 92 blazer, & lines my climat control only blows air from defrost and floor no vent at all,need help with this one. any ideas
Old 11-16-2005, 07:43 PM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Re: vacuum ball in 92 blazer?cant find?
Your vacuum lines are located behind your plenum. You should have a check valve that splits the line into 4. I would start there and trace to vacuum lines looking for leaks. 9 times out of 10 your check valve is shoot and needs to be replaced. Hope that helps.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 11-23-2005, 01:44 PM
Talking found it
i took out the climat control switch, and found where all the vacuum lines conect to it in the back . on the other side of the circular connection there is a small black round plug, its ends where cracked and was not holding everything tight. i went to the junk yard found an old switch, replaced the little plug and now it runs like new again. thanks for your help though. glad i didnt have to tear apart my hole dash.
Old 11-23-2005, 01:59 PM
Gabe25's Avatar
Re: found it
Good for you. Ya, tearing about the dash can be the pits..
Aloha
Gabe
My Fleet
