Old 11-16-2005, 05:57 PM
gbic1 gbic1 is offline
T5 4 cyl to 5.0 Will it fit
Can any one tell me if a T5 5 speed from a four cylinder will interchange with the v8. Fox body
1967 cougar 390 FE in progress
1993 F350 Crew Cab 5.8 111K
1983 Coachman 23ft class C 460
1988 Bronco 351 C6
1964 Galaxie 428 4sp project
1995 Mustang 3.8 Auto
1966 Mustang Fast back Project
1994 Tracer Trio 1.9
1968 F250 Camper Special 390
Old 11-16-2005, 08:09 PM
neatofrito1618 neatofrito1618 is offline
Send a message via AIM to neatofrito1618 Send a message via Yahoo to neatofrito1618
Re: T5 4 cyl to 5.0 Will it fit
yes it will
Old 12-04-2005, 01:54 PM
ox3782 ox3782 is offline
I Heard That There Is A Difference In Pilot
Bearing Sizes
Old 12-07-2005, 01:50 PM
Jimmmy Jimmmy is offline
Re: Re: T5 4 cyl to 5.0 Will it fit
The piloit bearing is from an 85 desiel ranger. The only difference between the two trannys are that the 4cylinder has different gear ratios in it. So it will seem like you have 4.10s when u really only have stock gears.(They are really steep!)
The reason why u need a different pilot bearing is becuase the snout on the 4 banger trans input shaft is longer and a little bit skinner in diameter.
I run a 4 cylinder tranny in my 5.0 stang and it's great!
Old 12-07-2005, 01:53 PM
TheStang00's Avatar
TheStang00 TheStang00 is offline
just boost the shit out of that 4 cyl!
Old 12-08-2005, 09:50 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Re: Re: T5 4 cyl to 5.0 Will it fit
I believe the T/O bearing is different too.
How much longer do you expect that tranny to hold up? They are not rated to handle a lot of torque.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 12-08-2005, 11:36 AM
Re: Re: Re: Re: T5 4 cyl to 5.0 Will it fit
Ford rates the 4 cylinder tranny at about 240 ft/pounds for toruqe. It depends on which year. I used the same throw out bearing, so i don't know about that.
Its holding up fine for me so far, but i have only used it for a couple of months now. Just be easy on it and it should last a while.
Old 12-28-2005, 11:58 AM
InUrHead InUrHead is offline
Send a message via Yahoo to InUrHead
They could almost be two diff trannies. The 5.0 is if I remember correctly, a "world class T-5" which is loads stronger than your 4 cyl T-5 (got a scrapped 4 cyl T-5 for proof, didn't last a month mated to a 306 with bolt ons). Anyways, hope the tranny holds up better for you than it did us.
The best way to change someone's mind is with a rock.
