Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 11-16-2005, 04:27 PM
ericolds82 ericolds82 is offline
car stalls!
can any one tell me why my delta would stall when i give it gas?
when i press the gas pedal the car hardly moved and then stalls but start right back up.
thanks for any help that may be given
Old 11-16-2005, 05:40 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: car stalls!
It is possible that the throttle position sensor is bad and needs to be replaced. That would be a good place to start. Otherwise it could be the crank position sensor causing the issue. Try the throttle position first and the CPS next.
Old 11-16-2005, 11:02 PM
Re: Re: car stalls!
Thanks for the help!!do an 1982 delta have these sensors on it?
And where are they located? ericolds82
Old 11-22-2005, 09:04 AM
razr_88 razr_88 is offline
Send a message via Yahoo to razr_88
Re: Re: Re: car stalls!
i'm not sure were the sensors are, but you can pick up a HAYNES manual at the library or your local auto store.... that should help a little...
