Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 11-16-2005, 03:43 PM
DeputyMoniker DeputyMoniker is offline
Optima doesn't fit 2002 Eclipse Spyder GT?
I checked the local part shop & their book didnt list an Optima for the Spyder GT. Theres one for the Eclipse, but not the Spyder. So I got onto the Optima website & they dont list one either. Is this true? No Optima for me?
Old 11-16-2005, 04:06 PM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: Optima doesn't fit 2002 Eclipse Spyder GT?
are you talking about the battery?
since when do certain batteries fit certain cars? aren't most of them universal batteries?
oh, and when it comes to batteries, the coupe and the spyder are the same. so if the battery fits an eclipse...it will fit the spyder
Old 11-16-2005, 06:21 PM
Re: Re: Optima doesn't fit 2002 Eclipse Spyder GT?
Well, the Optima site shows the 25O or the 75DTO will fit a 2000-2004 Eclipse if you use the height adaptor. It shows nothing for the 2001-2004 Spyder. I suspect it would be listed if it would fit. What kind of battery are you guys using?
Old 11-16-2005, 08:53 PM
Re: Re: Re: Optima doesn't fit 2002 Eclipse Spyder GT?
the spyder is the same car as the eclipse. THE ONLY DIFFERENCE IS THE CONVERTIBLE. spyder means convertible. everything else is exactly the same(some exceptions but you don't have to worry about them).
if you start looking for mods that actually list for the spyder, you will not find anything. just about every company will list parts under eclipse...not parts for the coupe and parts for the spyder. if it is listed for the 2000-2004 eclipse then it will fit both the coupe and the spyder.
i am using the stock battery. never seen a reason to buy one of the other ones.
Old 11-17-2005, 12:53 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Yeah...as long as mine still puts out 14.0V+ my stock one is just fine for me.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 11-17-2005, 07:19 AM
cficare68's Avatar
cficare68 cficare68 is offline
I am using a stock battery right now. But I am looking into getting a Optima Yellow top and a bigger alternator. I'm running too much power on the stock ones
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads.
Old 11-17-2005, 09:15 AM
I bought an Optima red cap. eclipsed4utoo was right, if its listed for the regular eclipse V6 then itll fit the spyder too. It fits and works fine so Im going to throw some keywords in here so it'll come up if someone else needs to know if it will fit.
2000 2001 2002 2003 2004 2000-2004 '00-'04 00 01 02 03 04 eclipse spyder spider GT GS optima red yellow redcap yellowcap
Old 11-17-2005, 09:51 AM
good job.
Old 11-17-2005, 01:06 PM
cficare68's Avatar
LOL. But you forgot 2005, 05, GTS or GTS Spyder.
Old 11-17-2005, 01:34 PM
rodbls's Avatar
This is for DeputyMoniker. Just to let you know, your battery is only as good as your alternator. Putting in a "better quality" batter will only help when it's really cold out because it probably wont drain as fast when the car is OFF and sitting. Your alternator is what powers your car when it's running for the most part. This is why your lights dim and you lose performance if you are blasting music (aftermaket system of course). Your battery can not handle the power needed to blast your system, and if your lights dim it is because your alternator is underpowering your battery. If you want to notice any improvement you would have to upgrade your alternator...not exactly a cheap upgrade either, i think a 250amp alternator is about 800.
Old 11-17-2005, 02:57 PM
have you found any alternators that are made for the 3G? i know a couple of people have looked into them, but couldn't really find anything.
Old 11-17-2005, 05:43 PM
rodbls's Avatar
No, I have found alternators with the amperage that I want (250-300), but have yet to hear back from them if they will fit our cars. My guess is no because our stock alternator is only 80amps...so it needs to more than tripple its output. BUT, im sure there are some out there, I just need to get in touch with the right people. I will post a thread if I ever find anything.
Old 11-17-2005, 09:10 PM
The only reason I got a new battery is that my old one was leaking. I chose Optima because theyre gell cell, sturdy, have a good guarantee and I get a great deal on them. ($99 including tax)
Old 11-17-2005, 10:43 PM
cficare68's Avatar
Found this post at club 3g about alternators for the 3g
http://www.club3g.com/forum/showthread.php?t=30989
Old 11-18-2005, 09:37 PM
Suddenly my car doesnt work. Its idling too low and it cuts off at stop lights. ><
Think it has anything to do with the battery?
