Old 11-16-2005, 03:39 PM
sLADe781 sLADe781 is offline
Downshifting for stops
I was wondering when you guys come to a stop, do you just put it into neutral and step on the brakes or do you start downshifting to slow yourself down? I used to downshift to slow down before I start the brakes but then I stopped doing that because I was thinking that it'll wear my clutch down quicker. As a result, I figured it'll be cheaper and easier to replace brake pads than a clutch so I just pop it into neutral and brake. What about you guys? What do you do and what are the advantages of one over the other? Just curious....
Old 11-16-2005, 04:09 PM
unicyclemidget11 unicyclemidget11 is offline
Re: Downshifting for stops
downshifting is wear on the clutch and wastes your gas more than anything whereas using your brakes just wears out your brakes faster
Old 11-16-2005, 04:34 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
I put it in neutral and stop...
now my brakes were going for a while so I used to downshift, and brake with no clutch, and poped the clutch back in before the RPMs got too low... that made the car break pretty damn quickly... I only did that though if I had to stop really fast.
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 11-16-2005, 05:59 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: Downshifting for stops
That is actaully incorrect. Engine braking saves gas from what I have read. And downshifiting to slow down is not THAT hard on your clutch. Our old Dakota had 167k miles on the STOCK clutch and it was engine braked its entire life. Engine braking is easier on the car than just popping it in nuetral and hitting the brakes.
Old 11-16-2005, 06:37 PM
deagle50ae deagle50ae is offline
not to mention, many states in the US require you to downshift. neutral coasting is against the law.
on the other hand...
here in MN, a local guy got a ticket for it. the cop said he was revving. ticket was for exhibition. he challenged it in court. never heard what the outcome was.
Old 11-16-2005, 06:48 PM
^ WTF man, that I just don't understand... from what I know, all the auto cars put the car in neutral when you take your foot off the gas, so everytime you take your foot off the gas and you have an auto you're braking the law...
my dad talked to me about this, and he said that in the old carburator cars it used to wear out the carburator or the piston rings prematurely or something....
Old 11-16-2005, 07:13 PM
planet_keeper's Avatar
planet_keeper planet_keeper is offline
im a little confused about downshifting to stop saving you gas. i would think that because you are reving it a couple times before stopping rather than letting it go down to idle, its using more gas.
Old 11-16-2005, 07:58 PM
Stealthee's Avatar
The injectors shut down basically.
Rocker your dad is nuts.
Old 11-16-2005, 08:53 PM
^ROFL!!!!
well sometimes he tends to get ahead of himself, but sometimes he knows what he's talkin' about... I guess this just wasn't one of his times though...
Old 11-16-2005, 09:18 PM
automatics dont go in neutral when you let off the gas. often times they go to the highest gear to keep the revs low. plus the fluid in the torque converter allows the wheels to spin at different speed then the engine. you you drive an auto, coast in it while in gear, then pop it in neutral. you'll notice a big difference in the drag created by the drivetrain
but I'm no expert. i could be way off base here.
Old 11-16-2005, 09:48 PM
Stealthee's Avatar
Re: Re: Re: Downshifting for stops
You are basically correct. Autos gear down to aid in slowing you down.
Old 11-17-2005, 07:24 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
even at that, you can engine brake in an auto... though I hear that can be rough on the tranny... but my buddy does it in his 2004 all the time...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 11-17-2005, 07:34 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
If you dont want to wear out your clutch or syncros just double clutch. That way you can still engine brake, without the extra wear. You may notice this is less effective because you are truely engine braking instead of braking by using the inertia from the engine.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 11-17-2005, 08:58 AM
ouch. I tried e-braking in my mom's 2001 accord (auto) and it jerks so hard it feels like i'm running over school children. makes for an uncomfortable ride.
but I e-brake in my '92 olds (auto) all the time because my brakes dont work so well..... so into second gear at 55, and into 1st gear just under 40 hehehe, i beat the hell out of that car. but it runs perfect 200,000 on the clock
Old 11-17-2005, 09:04 AM
Mikelb's Avatar
^yeah, those olds are built... they take one hell of a beating... my neighbors got one... and I don't know how that things survived... but aside from a dead battery/bad alternator... it's still running strong....
