Old 11-16-2005, 02:26 PM
Minnda Minnda is offline
Send a message via AIM to Minnda
Camshaft and crankshaft......
Ok, i have a '97 cavy and its throwing codes for the camshaft positon sensor, and as i have been reading people have these codes then find out its something to do with an anti-theft something or other. I need to know what it is and how that part of it was fix. My car has been stuttering and then dies when it rains. It also idles hard when it is wet. I'm also looking to see if this camshaft positioning sensor is in a place that i can fix it myself......i need the help
Old 11-24-2005, 04:50 PM
catfisher62040 catfisher62040 is offline
Send a message via AIM to catfisher62040 Send a message via Yahoo to catfisher62040
the cam shaft sensor is located right above the crankshaft sensor. if you can get under car and identify where the coil packs are located the crankshaft sensor is located right below coils and the camshaft is to the upper right of the crankshaft. spuddering when it rains are is wet sounds more like a plug wire loose on coil packs
When i die i want to die like my grandpa, peaceful and asleep, not screaming like the passengers in the back seat of his car.
Old 11-24-2005, 06:07 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Camshaft and crankshaft......
What engine and what code no. are you getting?
MT
