Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 11-16-2005, 02:15 PM
ottokin ottokin is offline
Question PLEASE HELP ME somebody.....
Please help me ANYONE...'93 JGC Larado... I turned on 1 of my rear overhead dome lights by pushing it in. It was stuck and stayed in the pushed-in position. My son deceided he would try to get it out and was pushing on the other 1 and needless to say, that one got stuck pushed-in also. Now I got the 2 back out, the dome lights are real dim and they all go on and off together. The radio and dash info center are not working at all and are completely off. When you open a door, the domes are dim and there is a constant clicking/ticking from the area of the fuse block, till the door is shut and begins again as soon as the door is open again and stays ticking as long as the door is open.
The overheads do not go on when the doors are open, only the lights under the dash and my power door locks no longer work.
What maybe wrong?
Also, how do you remove the overhead console to check for loose wires or switches?
PLEASE HELP ME.......
Old 11-16-2005, 04:49 PM
jeeperphil jeeperphil is offline
Re: PLEASE HELP ME somebody.....
sounds like a bad relay or a short causing the relay to click, trying to engage and failing over and over.
check what relay goes to any of the simptoms and replace it or look for frayed wires leading into the fuse box.
Old 11-17-2005, 03:06 AM
CrxFreak91 CrxFreak91 is offline
check the fuse between the pass. door. that same thing happened to my 93 jgc.
Old 11-17-2005, 09:18 PM
Re: Re: PLEASE HELP ME somebody.....
Where would I look and find this fuse in question?
Old 11-18-2005, 12:08 AM
glass glass is offline
excuse me??... the problem is sticking switches , and your looking for fuses or wires ?? ........
just a thought
Old 11-18-2005, 05:42 AM
excuse me.... the radio is not working, the info center doesnt work.....ottokin open the pass door look in the fuse panel. the second column from the left, there should be four. and its the second or the third fuse down. sorry im not sure i have no fuse cover and i did that awile ago and my radio, info center works now the clicking stoped. but the sticking over head light is a different subject could just need cleaned or replace???? try that and let us know..
