I have codes p0171 and p0174 they say system to lean. Help please :0(
Re: Codes what are they
That's as good as it gets with the codes. You're gonna have to check stuff. Here's a list of possible causes.
Fuel System: · Contaminated fuel injectors · Low fuel pressure or running out of fuel (fuel pump, filter, fuel supply line restrictions) · Vapor recovery system (VMV) Induction System: · MAF contamination · Air leaks between the MAF and throttle body · Vacuum leaks · PCV system concern · Improperly seated engine oil dipstick EGR System: · Leaking gasket · Stuck EGR valve · Leaking diaphragm or EVR Base Engine: · Exhaust leaks before or near the HO2S · Secondary air concern Powertrain Control System: · PCM concern Since both sides (banks) of the engine are showing lean check for leaks in the intake system or a vacuum line, Dirty MAF sensor, something that affects both banks of the engine. |
