Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 11-16-2005, 02:20 PM
braaaph braaaph is offline
Question Adjusting headlights on 2001.5 Passat
1st post...so here we go...
I just recently purchased a 2001.5 VW Passat through a private deal. The headlights are very low. Actually if I leave my high beams on, cars coming towards me don't even "grill" me as I think they are probably at the level my low beams should be at.
The question I have is does anyone know how to adjust the headlights? Or is this something I should be bringing to a VW garage? I've owned plently of Chevy's, Fords, Dodges were it was pretty simple to adjust but this is my first VW...which by the way I love!
Please help or maybe direct me to another place that can.
Thanks!
Jim
Old 11-17-2005, 10:16 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
u sure your low beam bulbs arent burnt out. they do burn out alot on passats.
adjusting headlights is done by a 5-6mm allen wrench. there are arrows pointing to the adjusting points.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 11-18-2005, 10:55 AM
Talking Re: Adjusting headlights on 2001.5 Passat
Thanks for the response veedub. I'm going to check tonight if the low beam bulbs arent burnt out. Are the arrows on top of the headlight housing?
Old 12-17-2005, 04:09 PM
speedtriple speedtriple is offline
Re: Re: Adjusting headlights on 2001.5 Passat
Have you noticed the 2 adjustment tumblers below the steering column? - 1 is for the instrument brightness and the other is to adjust the headlight beams - if memory serves me the one on the right is the one to use to adjust.
