Old 05-29-2002, 06:07 PM
88ReX 88ReX is offline
which fuse to pull?
I need to reset my ecu however I am unsure of which fuse to pull....they say to pull the "hazard fuse" but I dont see that anywhere on my panel, is it located somewhere else or do I just pull the turn signal fuse?!?!?!
Old 05-29-2002, 07:05 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Fuse?
Just disconnect the battery terminals.
Old 05-29-2002, 08:16 PM
tyVm
Old 05-29-2002, 09:08 PM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
the correct fuse to pull is under the hood on the passenger side. it is marked "ECU". if your standing on the passenger side it is the second fuse down from the top on the left hand side. Should be a 15 amp fuse.
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
