Old 11-16-2005, 09:34 AM
tmylwgnr tmylwgnr is offline
Send a message via Yahoo to tmylwgnr
Question Help Please!!!!
Okay guys, I need some expertise here. If one of you guys can help me with this problem you would make me the happiest girl in the world.
I have a 1994 Camaro Z-28 with the LT1 engine w/ auto 4 speed trans.
Here is my problem, while moving across the U.S. my car was parked for about an hour and a half while I had dinner. When I returned to the car, it would not start without pumping the hell out of the gas pedal. I figured maybe it was out of gas (gas gauge said it had some gas), finally got it started after several back fires and got it to stumble and back fire to the end of the restaurant parking lot to a gas station, filled the tank and still the same thing. made it maybe two blocks and the car stalled and would not start now AT ALL.
The car has set for a couple of months and recently I had it checked and it had no spark. So changed the Optispark, had fire and gas but still just turns over and won't start, I had the timing chain checked, everything good there. I took it to a friend and had it put on the computer, Air flow map sensor was not registering. So yesterday, I replaced the air flow map sensor and also the maf sensor (just in case). Still NOTHING! It has spark, gas and oil pressure but still it only turns over and won't start - it tries to start, almost hits and then nothing!
Now I am lost, can some here please help me? PLEASE ---- I AM DESPERATE!
Old 11-16-2005, 10:16 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Help Please!!!!
Did you try re-setting the ECM after replacing the map?
Old 11-16-2005, 12:42 PM
Re: Re: Help Please!!!!
How do I reset it? Please let me know! Thanks!!!!
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: Help Please!!!!
Agreed. defintely try reseting the computer. the only other things i can thing of are possible valvetrain failure (not likely) and loss of compression, do a compression check.
reset computer by unplugging negative terminal from battery for ten minutes, then reconnect.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 11-16-2005, 12:50 PM
wrightz28's Avatar
Re: Help Please!!!!
what he said
Old 11-16-2005, 12:59 PM
I have good compression. I will try to reset the ECM
Old 11-16-2005, 10:36 PM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
Re: Help Please!!!!
It two things to fire:
1 gas
2 spark
3 compression.
Even if it had a bad head gasket it would fire.
It looks like its the fuel pressure issue or computer failure. The engine is probably dry.
I dont know about the spark issues. Its strange that so many things would fail at once. I would defenatly look at the computer.
How is the battery . ( dont laugh-things like that happen-it will turn over, but wont start)
Whats up with it had no spark? It was running at first right, maybe bad, but running.
How much did it all cost to you?
Old 11-18-2005, 07:53 PM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
Re: Help Please!!!!
damn when was the last time u got some plugs and wires??
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
Old 11-19-2005, 02:44 PM
Talking Re: Re: Help Please!!!!
I put new plugs and wires in it just two weeks before the car went down. I think my 'new' optispark maybe part of the problem, when we ran the testing it the optispark fires 3 or 4 times and then delays and then fires 3 or 4 more times before delaying again. I am in the process of replacing with another new optispark and new cap and rotor as well, just in case. I have no even calculated the money I have put into it yet. I will let you know as soon as I get it running. I am now a driven woman!!!!
By the way, I have gas, fire and compression! And, I have reset the ECM as well!
Old 11-19-2005, 03:36 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: Help Please!!!!
The holdign the gas pedal to start, and rough running, sounds to me liek you might have a vacuum leak somewhere
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 11-23-2005, 11:41 AM
First off I would like to say thank you to everyone for their input. Secondly, I am happy so say that my car is now running!!!!!
After replacing almost everything that I could think of and getting down it being either the computer or the coil. I had the coil changed and she started right up. I did have to replace the optispark as apparently I had an oil leak from the two seals behind the optispark and so I had oil in my opti. Anyways, she is now running and I am most definately the happiest girl in the world!!!!
Thanks to all of you guys again and a special thanks to 89IROC&RS for his allowing me to stalk him out for help on e-mail.
I hope you all have a happy thanksgiving!!!
Tammy
Old 11-23-2005, 04:12 PM
Matt365's Avatar
Matt365 Matt365 is offline
Send a message via AIM to Matt365
Re: Re: Re: Help Please!!!!
Tammy
he probably didnt mind a girl stalking himfor once instead of TS
