Old 11-16-2005, 07:43 AM
bruthru2002 bruthru2002 is offline
TCC Shutter
Hello all! My fiancee has a 1995 Lumina 3.1 (M code it says) and it has the classic signs of the TCC shutter. I was looking though and found that I could take the fuse out for the TCC to see if it was actually it. I read in the owners manual that the fuse for the TCC is in the fuse box under the hood. When I checked the box under the hood, there was no fuse there for it. It says its for fog lights or something like that. Anyone have any ideas or can anyone tell me exactally where the electrical connector is for the tcc to i can try to disconnect it there. Thanks.
Old 11-16-2005, 08:14 AM
maxwedge maxwedge is offline
A990 racer
Re: TCC Shutter
No fuse for the tcc this is pcm controlled, it is easy to confuse an engine buck or misfire that only occurs under load when the tcc is engaged, for an actual tcc problem. Further diagnosis is required, a scan with a full trans scanner can determine if the tcc is slipping.
Old 11-16-2005, 01:34 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: TCC Shutter
The older ones had a dedicated fuse for the TCC in the interior fusebox on the passenger's side of the dash, but I never looked in my '97's fusebox.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 12-01-2005, 09:05 AM
comptech_69 comptech_69 is offline
Send a message via AIM to comptech_69 Send a message via Yahoo to comptech_69
Re: TCC Shutter
pull the wire on the transmission, that's the simplelest way to do it... Its on the right side of the car on the transmission itself underneath the airbox.
www.theimportkiller.com
