Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 11-15-2005, 09:53 PM
Ron722 Ron722 is offline
86 HF running hot
I just bought a 1986 HF with 180K miles on it. When I bought is I noticed that when running that the temp gauge would be about half way to hot. Today on the way home it was running closer to 3/4 of the way to hot. Wierd part is it just started getting cold out here. Today it was about 30 degs out.
Any ideas?
Old 11-15-2005, 10:15 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
Re: 86 HF running hot
Check your thermostat... It could be stuck closed... Although, that is highly unlikely. Is it only getting hot when you sit still or whenever you have the car running (driving or not)?
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 11-15-2005, 10:18 PM
Re: Re: 86 HF running hot
I drive 30 miles on the freeway. This is when is when I noticed it was running hotter than normal.
Where whould the gauge be? My brother has newer Hondas and thought that 1/2 way was a little hot.
Old 12-08-2005, 02:09 AM
dredknought's Avatar
dredknought dredknought is offline
Send a message via AIM to dredknought Send a message via MSN to dredknought
Re: Re: Re: 86 HF running hot
i have the same problem. i'm about to tos a 92 integra radiator in to try an fix it. (bigger area for cooling) but i think it might be my thermostat messing up because my engine doesn't seem to be that hot it just reads it is. i don't know any info could help. thanks
Old 12-08-2005, 02:15 AM
86 HF running hot
oh yeah my car is an 87 crx with 1.6l pgmfi fuel injected motor
Old 12-08-2005, 09:20 AM
I grabed the lower radiator hose when the car was warm and it was still cold and top one was warm. So I replaced my thermostat and it seems to have helped. It is still going to about 1/2 way on the freeway but not 3/4 any more. I find it hard to belive it is the radiator becuase it is about 4 degrees out the last few days.
This summer I plan on replacing the timing belt and will put a new water pump on too.
Old 12-08-2005, 12:31 PM
Figori's Avatar
Your thermostat might have been stuck shut... Causing the hot water to never leave the motor. You should have fixed the problem with that.
