Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 11-15-2005, 08:40 PM
rx7bsebal2oo6 rx7bsebal2oo6 is offline
How to?
How do you turn your stock 3.0 V-6 engine into one that has dual cams?
Old 11-15-2005, 08:56 PM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: How to?
the V6 has two cams.
Old 11-15-2005, 09:39 PM
evil6remlin evil6remlin is offline
Re: How to?
I believe you are asking if it is possible to swap to a DOHC head correct? If so there has been talk that it is possible to bolt up the vr4 head up to the engine but that you will have clearance issues with the rear bank head and the firewall. So even if they do bolt up they won't fit anyway without a good bit of fabrication which would probably not be worth it anyway. Do a search on here and on club3g.com cause its been discussed many times before.
On an unrelated note: is anyone having problems getting on club3g? Everytime I type it into my browswer it takes me to www.muellerized.com which I assume is a joke but my girlfriend can get there fine at her college so I don't know what's up.
Old 11-16-2005, 07:15 AM
cficare68's Avatar
cficare68 cficare68 is offline
Re: Re: How to?
http://www.automotiveforums.com/vbul...d.php?t=481563
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads.
Old 11-16-2005, 07:46 AM
Re: How to?
yeah they are having major problems at club3g. originally, they switched servers b/c the current company that was hosting the server had horrible customer service. so they switched to this other company that they thought was better. well, they were better but that company had a limit on the usage of the site. so we were constantly getting server errors when we hit that limit.
so they switched to another company that many other car forums use. well during this switch, the second company totally deleted the account and the DNS name from all records. this is why you were having to use the IP of the site. After two days of the DNS not updating so that you could use the site name, the admins checked on it. thats when they found out about the account being deleted.
The solution, JR(Strider) is the guy that runs the site for RRE.com and Mullerized.com and he was going to add club3g.com to his package with that same company. So it seems that the company has the sites mixed up and is showing the mullerized.com site instead of club3g.com.
Now to answer the question....the bolt pattern of the VR4 head is different from the 3G V6 bolt pattern. so even if you did the modifications to the firewall to make it work, you would have to drill new holes. have fun with that.
Old 11-16-2005, 10:13 AM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: How to?
the SOHC setup is also designed very well and you shouldn't need to add another cam for any N/A applications because it will not yield a substancial gain
Don't act like you don't love it.
503/2000
Old 11-16-2005, 01:12 PM
Re: Re: How to?
agreed. if you are trying to build a 30psi+ engine, then yes, you should look into the swap for the ability to tune the engine better. but if you are not going to be a track/dyno queen, then it is not a practical swap.
