Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-15-2005, 07:50 PM
crabby760 crabby760 is offline
torque specs... help
i need torque specs for the following things
b16a motor
head bolt specs
Old 11-15-2005, 07:54 PM
iVteC_PoWeR iVteC_PoWeR is offline
Send a message via AIM to iVteC_PoWeR
Re: torque specs... help
The first b16a motor has 111lb/ft@7000rpm
Old 11-15-2005, 09:24 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
What year/make/model/engine/etc.... Different years and makes have been known to have different specifications. You did mean torque specs, not engine torque output, right?
Old 11-15-2005, 09:39 PM
yea lol.. torque specs... for the head bolts
92 b16a
Old 11-15-2005, 09:48 PM
These require 2 settings:
First setting: 22 ft. lbs.
Second Setting: 61 ft. lbs.
Old 11-16-2005, 02:09 PM
also need torque specs for the cam caps...
Old 11-16-2005, 03:30 PM
Tighten the camshaft holder bolts for 1984-91 to 16 ft. lbs. (22 Nm). For 1992-95 engines tighten to the following specifications:
8mm bolts:
D16Z6, D15Z1 engines: 14 ft. lbs. (20 Nm)
D15B7, D15B8 engines: 16 ft. lbs. (22 Nm)
6mm bolts:
All engines: 9 ft. lbs. (12 Nm)
Old 11-16-2005, 03:48 PM
i have a b16a 92 motor... dohc vtec
also how do i tighten the timing belt... i can't get it to tigthen correctly.. 1 side is tight the other is loose...
Old 11-16-2005, 03:57 PM
I'm having a hard time finding a procedure. What model honda did your engine come from?
Old 11-16-2005, 05:29 PM
not sure i think the 92-95 sir hatch b16a
Old 11-16-2005, 05:44 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Re: torque specs... help
i dont know what everyone else is saying up there, but, this is correct. sequence is:
9 5 1 3 7
8 4 2 6 10
as for specific years someone was refering to up there. the b18c5, b16, b18a/b, and b18c5 all have the same specs.
the crankshaft and camgears need to be at TDC with the belt on. to properly tension, rotate the camgears three teeths apart then tighten the tensioner. the belt tension between the two camgears should be tight. the tension between the ctankshaft and exhaust camgear should be no more than an 1 inch deflection.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-17-2005, 12:03 AM
after i put on the cam caps... i cannot turn the cams i try turning them with a rachet but they wont turn... did i do sumthing wrong..?
also how do i set the timing rite..? do the cam gears have to be a certain way???
also wat is the valve adjustment specs..?a
Old 11-17-2005, 09:36 PM
I'd say your cam caps are over tightened, bad.
Old 11-17-2005, 10:01 PM
Here's a link for valve lash adjustment:
http://www.autozone.com/servlet/UiBr...3d80140dd9.jsp
Old 11-17-2005, 10:03 PM
I can't even find anything on timing belt procedures....
