Old 11-15-2005, 06:08 PM
greesemunkee7's Avatar
greesemunkee7 greesemunkee7 is offline
Send a message via AIM to greesemunkee7 Send a message via Yahoo to greesemunkee7
400 crank?
hey i was just wandering how you tell what kind of crank you have. on my 383, i have a four bolt main, but just curious if i can find out the size of the crank.
cam too. i was told it was an RV cam when i bought the motor, but the guy didnt sound too sure. neither am i. any help on that?
Old 11-15-2005, 06:49 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: 400 crank?
take it to a machine shop.... they can measure it exactly and tell you. or you can try measuring it yourself.
measure the distance between where the connecting rods mount (the centerline of that point on the crank) and the absolute center of the crank (the point around which the crank itself rotates), in inches, and then multiply it by two. this should be the length of your stroke. if it is larger than 3.48 inches it's not a standard 350 crank.
i've never done this myself and the above is the theoritical approach of how to find about.... i might be overlooking something.
also, the cam isn't worth the time it takes to find the specs. sell it to the recyclers and buy a new one if you want performance, if you just want the engine to run and you don't care, lube it up and put it back in.]
Cams are cheap, $70-100 for a good one. Now is the time to do it, while you've got the engine out of the car. it will be a pain to do a cam swap later.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 11-15-2005, 07:11 PM
sounds good
Old 11-16-2005, 12:44 AM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
Re: 400 crank?
Kevin, have you taken your car to the track yet? And have you been around recently? For some reason, I don't remember seeing you post recently, although Maybe I missed it.
Old 11-16-2005, 11:29 AM
Re: 400 crank?
its been some months now since i've posted. I posted the 700r4 transbrake thread.. http://www.automotiveforums.com/vbul...d.php?t=482639 recently.
haven't been to the track yet... still not ready, need posi-trac rear and need to custom make 3" mandrel exhaust... starting on that next week. I'll post a full update tonight.
