Old 11-15-2005, 05:21 PM
slowCRXinPitt's Avatar
slowCRXinPitt slowCRXinPitt is offline
swap woes
got the d15 b vtec in. Drives fine in first gear but has no power in any other gear. Also a small fire started in the heater box... thats what the mechanic says anyways.... what coulda caused this? He denies any responsibility.
Old 11-15-2005, 05:27 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Re: swap woes
Smoking any? Oil in coolant? Compression test?
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
Old 11-15-2005, 06:08 PM
Well he says that it was an electrical short. no oil in coolant, no smoking and great compression. Any ideas?
Old 11-15-2005, 09:23 PM
Re: swap woes
I don't see how an electrical short would cause loss of power in 2-5 gear. Sounds like he is BSin you.
Old 11-15-2005, 09:36 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: swap woes
a short in the wiring could cause a small fire in your heater box.
as far as the engine not having any power. what tranny r u using ? have you done a tune up on the engine ?
Team Lonely Drivers
Old 11-18-2005, 09:28 AM
Re: Re: swap woes
so he could have caused the short by mis-wiring something?
I'm using the si tranny, has no grings at all and ran fine prior to the swap. What kind of tune up do you suggest?
Thanks for the feedback.
