Old 11-15-2005, 06:06 PM
madchildz madchildz is offline
trouble code retreival
i was just wondering how i go about retreiving trouble codes on my 88 cherokee????????????????
Old 11-18-2005, 07:14 PM
Jeepme Jeepme is offline
Quote from Haynes manual, "On 1990 and earlier models, with the exception of models equipped with a V6 engine, a special tool (Chrysler DRB-ll or equivalent) is needed to access the self-diagnosis system."
Old 11-19-2005, 01:02 AM
95xjsport 95xjsport is offline
Send a message via AIM to 95xjsport Send a message via Yahoo to 95xjsport
Re: trouble code retreival
what about a 98 cherokee> can I do it without the scan tool?
Black 99 Jetta GLX VR6
Black 92 BMW 525I
Blue 95 GMC Jimmy SLT 4.3L VORTEC V6 (Sold... Junk)
Green 98 Jeep Cherokee SE (totaled Electrical fire)
Red 95 Jeep Cherokee Sport (Gone)
Green 93 Jeep Grand Cherokee Limited (for sale)
[email protected]
"Racing a ricer is just like competing in the special olympics, even if you win your still retarded"
Old 11-19-2005, 04:41 AM
integrawhat integrawhat is offline
Send a message via AIM to integrawhat
98 is obd2 so not completly sure but on my 93 you just turn the ignition to on (not start) and back off i think five times and then the cel flashes certain sequenses to tell you the codes
A.K.A. GOT WIDE
darton 84mm MID's ls stroke 2.0l GS-R
pnp head with full skunk2 pro series valve train
and pro1 cams
custom divided top mount w/garrett gt4094r
not stoping till i hit 750hp to the wheels
this aint your mom's car so DONT F***ING TOUCH IT
Old 11-19-2005, 10:03 AM
three times, I was told by www.webejeepin.com that that would work on the 97 TJ, if my memory seerves me correctly thery have the same engine, computer, ect... but that dosn't seem to work on mine
Black 92 BMW 525I
[email protected]
Old 11-19-2005, 07:09 PM
baum430 baum430 is offline
on the 89 and 90 jeeps the DRBII will display fault codes for these
two years. 91 thru 95 Jeeps you can use snapon scanner. 96 and up
is OBDII and you can buy these code scanners cheap.
Old 11-20-2005, 05:55 PM
Saudade's Avatar
Saudade Saudade is offline
I got an OBDII scanner on eBay for $44 (including S&H). Works great and can reset MIL.
Doesn't work on my '88. But the earlier XJ's don't store codes, the connectors are set up for "run time" diags. The FSM gives you the pin outs that you can test with a meter.
Old 11-27-2005, 11:06 AM
vamc's Avatar
vamc vamc is offline
all cars from 1996 and older are all obd2. If they still made the yougo, and it was a 1996, it would as well have a obd2.
Old 11-27-2005, 12:06 PM
Saudade's Avatar
Re: Re: trouble code retreival
You must have meant 96 and "newer".
Old 11-29-2005, 04:44 PM
vamc's Avatar
Sorry, newer.
