Starting Problem
I've got a 2000 LS. In just the past couple of weeks, as the weather has turned cold, it intermittently has trouble starting. It turns over but quits right away. If you pump the gas, you can keep it going. In the old days - when I knew what I was doing - the problem would've been the automatic choke. I took it to the dealer and, of course, it wouldn't happen for them. They ran the diags on it, and nothing showed up. It's getting to be a pain in the butt. Any ideas?? Thanks.
Re: Starting Problem
thats the same thing my 1999 grand marquis is doing... won't idle and dies unless I warm it up manually. Last edited by rwilber; 12-18-2005 at 11:28 AM. |
Re: Re: Starting Problem
i tapped the cylinder with a screwdriver and the car runs perfectly. http://www.poolesville.biz/marquis.htm i drew an X on it...anybody know what it is? HELP!!!! Last edited by rwilber; 12-18-2005 at 11:30 AM. |
Found it...
thanks for the help. i didn't know it was called throttle body soo when I did a search on that and idle and 4.6L
i found waht I was looking for. so its the IAC Valve... """So let's revisit this IAC problem. I have a '00 GT 4.6L. My car would not idle, I figured it was running lean because of the K&N FIPK and the new throttle body. Since it was a work in progress with the intake and exhaust mods to follow I didn't really worry about it. Two weeks ago my car went in for a tune-up and the service manager told me I had a bad IAC. He said he could have it replaced for $300. I said no because of the work that I had planned. Well, later on I started to research it and thought about doing it myself. The IAC is located on the front of the intake. It is held on with two 5/8ths bolts. You unscrew the bolts, unplug a vaccuum hose and a sensor plug, take the assembly off and replace it with a new one, reversing the steps. The part from Ford is $100. I bought it from Autozone for $53 and replaced it in 10 minutes. On a side note, while I was in line at Autozone three people with various years of the 4.6L told me they had to replace their IAC valve, some more than once. It seems to me that Ford is either overlooking a defective piece of equipment on this engine or it is a wearable item that should be included in the tune-up schedule.""" http://www.autozone.com/servlet/UiBr...3d8014da1c.jsp ![]() i also found a quick fix that I didn't try and tahts just to disconnect the wiring from the IAC and adjust the idle screw on the linkage. instead of screwing around w/ the screw i'd probably just glue a piece of rubber to the idle plate... you probably won't pass emmisions and the car might run hot at idle.
problem solved
i took the black breather cap off the idle control valve
and while the engine was idleing fast i sprayed WD40 into the breather hole. lots of WD40. it works not more sticky valve |
Now I'm confused - did you replace the IAC or just "lube" it?? How difficult was it to replace it. Is is "easy" to get to? Any gaskets?? Any additioanl info on it would be most appreciated!! MB
BUMP!! I'm REAL curious about this one!!
![]() Here's some basic theory... Description and Operation PURPOSE The Idle Air Control (IAC ) solenoid allows the Powertrain Control Module (PCM ) to accurately control engine idle speed under a variety of conditions. The IAC solenoid is driven by an output signal from the PCM and allows intake airflow to bypass the throttle plates. In addition to normal idle speed control the IAC solenoid also functions as a deceleration dashpot and allows for idle speed changes during periods of increased engine load (A/C, electrical). The IAC solenoid also plays an integral role in Adaptive Strategy correction. The PCM monitors the engine condition and adjusts the IAC calibration to correct for wear and aging of components. NOTE : Whenever an IAC component is replaced or cleaned it is recommended that the Keep Alive Memory (KAM ) be be cleared. The vehicle may exhibit idle concerns until new adaptive values are learned. CONSTRUCTION A duty cycle driven solenoid is directly linked to a reverse seated pintle valve. The IAC solenoid may be constructed in one of two different styles. Hitachi With Vent/Filter This type of IAC solenoid is not serviceable and cannot be cleaned. OPERATION The IAC solenoid receives a 12 volt signal from circuit VPWR. The ground supply to the IAC solenoid is controlled by the PCM. The PCM controls the amount of IAC operation by varying the duty cycle of the ground signal. The IAC solenoid is linked directly to a pintle valve which controls the amount of intake airflow allowed to bypass the throttle plates. RELATED DIAGNOSTIC TROUBLE CODES DTC 412 Indicates that during the Key On Engine Running (KOER ) self-test, engine rpm could not be controlled within the self-test limit band. DTC 415 Indicates the IAC adaptive learning has reached the minimum learning limit (the valve is reducing air flow as much as possible). DTC 416 Indicates the IAC adaptive learning has reached the maximum learning limit (the valve is admitting as much air flow as possible). NOTE : Idle speed surging commonly results when the IAC solenoid reaches the limits of its operation. The IAC solenoid cannot compensate for the required change in idle speed which results in the engine surging between the upper and lower limits of the IAC system.
Jack of all trades...Master of none! Could someone please fix my Instant Email Notification? Please get back to us with your fix! Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Thanks Stevo - that was a REAL education on this part! Since you have already changed it what are the EXACT remove/replace procedures?? Thanks in advance....MB By the way, I have a '93 GM!
Just for my clarification - my '93 has nice power and runs real smoothe on the road. However, when I am at a stop light or sign with my foot on the brake and car in Drive the idle is not as smoothe as I would like. I have done plugs, spark plug wires, fuel filter and also air filter (K&N). Does this indicate a IAC problem? If not, what else?? Thanks....MB
Also run a can of SeaFoam throught the gas tank. You can get it at NAPA/CarQuest for about $6. www.seafoamsales.com
STEVO2 - Many thanks for the exact info. Please see my posting from 1/17/06- It describes my exact conditions. Does it sound like I need a IAC?? MB
Shameless Bump!!
How many miles on the GM? You would be wise to pull the error codes off the computer to see what's stored there. Also read this Service Bulletin. http://v8sho.com/SHO/TSB982310MassAi...tamination.htm
